N62 Belt Tensioner - Noise?
Old Aug 18, 2015 | 11:24 PM
aNo94's Avatar
Default N62 Belt Tensioner - Noise?
What does it sound like when the tensioner is going bad on our V8s? I'm getting an constant rattle/flutter from what seems to be the passenger side of the engine.
If it's not the tensioner, what are other possibilities? I have pulled out and cleaned both VANOS solenoids on the passenger side about a year and a half ago and the timing chains and guides were inspected when I had the valve stem seals done this past October.
Old Aug 19, 2015 | 04:54 AM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Pretty easy to take off the belt and test for the noise.
Old Aug 19, 2015 | 08:52 AM
EddieboyS's Avatar
My Ride: 2006 550i, 6 speed manual
Could be the water pump. My 06 550 has 93k miles on it and I'm on my 4th water pump.
Old Aug 19, 2015 | 02:47 PM
aNo94's Avatar
Is it just a matter of removing the belt and running the engine for a bit?
And Eddie...jeez, what brand were the water pumps?
Old Aug 20, 2015 | 04:59 AM
twh's Avatar
twh
Engine: N52
I imagine you'll get some messages, like not charging since the alternator is not turning. But, it is that easy as taking the belt off. Alternately you can get an automotive technician stethoscope like I have. Very useful in these cases.
Amazon.com: Lisle 52750 Stethoscope Kit: Automotive Amazon.com: Lisle 52750 Stethoscope Kit: Automotive
Old Aug 20, 2015 | 08:32 AM
EddieboyS's Avatar
1st 2 replacements were OEM under extended warranty. Not sure of the 4th as it was done by my new Indy shop.
Old Aug 20, 2015 | 12:53 PM
aNo94's Avatar
I'm going to replace both belts because as far as I know, they're original. If that doesn't stop the sound, I'll explore for noise from all the pulleys.
And Eddieboy, that is truly some bad luck with water pumps.
Old Aug 20, 2015 | 01:50 PM
westsidebalto's Avatar
My Ride: Sold: 545i, sport package, cold weather, 6MT
Engine: N62
Any chance it's the vacuum pump?
Old Aug 20, 2015 | 01:51 PM
ripley's Avatar
My Ride: 2007 E60 530d
Engine: M57
In the olden days before stethoscopes and the internet, mechanics would get their long screwdriver that had a hard plastic handle and stick the handle on their ear and the end of the screw driver on the suspect part.
Had to be careful with spinning things and belts though...
Old Aug 20, 2015 | 03:19 PM
aNo94's Avatar
I've considered that as well but the noise seems to stop when load is taken off from the belts...I turned the AC off to see if it made a difference and it did.
