N53 530i Extra torque when cold engine
Old Jan 6, 2013 | 06:14 AM
InlineSix's Avatar
Default N53 530i Extra torque when cold engine
What could cause that rarely (every 1 of 20 starts) car has more power (especially at 1000-4000rpm). It is quite noticeable difference. This happens mostly when weather is cold (below zero degrees) but not always. And this "power mode" last only 10-20mins. After engine is hot power is back to normal state. Lambda sensor could be one that comes in after engine is warm but how it could effect so much? What else could cause this?
Old Jan 6, 2013 | 07:22 AM
leew88's Avatar
My Ride: E60 530i LCI N53
During cold start, engine is programmed to run rich and ignition timing is optimised to suit hence te extra power felt.
I get the same feeling on all my cars, once hot engine it goes back to normal.
Old Jan 6, 2013 | 11:43 AM
InlineSix's Avatar
Sounds logical but it happens only sometimes. What I have read I think it might be faulty DISA. Have to check it soon.
Kasmo
Jun 27, 2024 06:02 AM
Stranger12
Apr 5, 2015 10:42 AM
ISUK
16
Nov 6, 2004 04:52 AM
LogicMan
Oct 24, 2003 09:48 AM
