MY2008 Engine Codes
Originally Posted by nicke60gre' post='477945' date='Oct 4 2007, 07:08 PM
We do need hard facts!
Remember that Wikipedia is only as wise as the sum of all writers...
How is your engine change project turning out?
Originally Posted by Ricracing' post='477949' date='Oct 4 2007, 07:23 PM
Hope - I'm sure - Mark can figure all this out...
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
Thanks, Hopefully it'll be ready until the end of October
![MY2008 Engine Codes-m53_engines.jpg](https://5series.net/forums/attachments/e60-discussion-2/38321d1482365433t-my2008-engine-codes-m53_engines.jpg)
Ok and then there is this version: I tried to re-format so you can at least read the important parts. I attached a pdf version.
SI B 00 01 07
Maintenance and General Hints September 2007
Technical Service
This Service Information bulletin supersedes S.I. B00 01 07 dated March 2007.
SUBJECT
New Vehicle Preparation and Maintenance Requirements
MODEL
2008 328i Sedan, 328i SULEV/PZEV, 328xi, 328xi SULEV/PZEV, 335i, 335xi (E90)
2008 328i Coupe, 328i SULEV/PZEV, 328xi, 328xi SULEV/PZEV, 335i, 335xi (E92)
2008 328i, 328xi Sports Wagon (E91)
2008 328i, 328i SULEV/PZEV, 335i convertible (E93)
2008 528i, 528xi, 535i, 535xi, 550i, M5 Sedan (E60)
2008 535xiT Sports Wagon (E61)
2008 650i, M6 Coupe (E63)
2008 650i, M6 Convertible (E64)
2008 750i (E65)
2008 750Li, 760Li (E66)
2008 Z4 Roadster 3.0i, Z4 Roadster 3.0si, M Roadster (E85)
2008 Z4 Coupe 3.0si, M Coupe (E86)
SITUATION
Model............................. Production Start*......... Comments
328i, 335i Coupe................ 9/07................ No changes from 2007
328i, 335i Sedan................. 9/07............... No changes from 2007
328xi, 335xi Sedan;
328xi Coupe........................ 9/07................No changes from 2007
328i, 328xi Sedan; 328i,
328xi Coupe SULEV/PZEV....... 9/07...............No changes from 2007
335xi Coupe..........................9/07................New Model
328i, 328xi Sports Wagon....... 9/07...............No changes from 2007
335i Convertible ....................9/07..............No changes from 2007
535xi Sports Wagon.................3/07............. New N52K (528i) and N54 (535i) engines.
.................................................. ................528i replaces the 525i, and 535i replaces 530i.
550i....................................... 3/07.............No drivetrain changes
M5..........................................3/07.............No drivetrain changes
650i Coupe, Convertible..........9/07............. LCI
M6 Coupe...............................9/07..............LCI
M6 Convertible........................9/07..............LCI
750i, 750Li, 760Li ....................9/07.............No changes from 2007
Z4 Roadster 3.0i, 3.0si ............10/07............No changes from 2007
Z4 M Roadster.........................10/07...........No changes from 2007
Z4 Coupe 3.0si .......................10/07...........No changes from 2007
Z4 M Coupe.............................10/07...........No changes from 2007
*availability approx. 1 month later.
The 2008 5 Series receives numerous equipment and design changes as part of the Life Cycle Impulse (LCI):
Front bumper
Headlamps
Kidney Grill
Tail lamps
Rocker panel
Interior material and trim enhancements
Electronic Shift Selector Lever on optional Automatic Transmission (similar to 2007 X5)
Optional "soft-close" doors on M5
New Engines for 528i and 535i:
Model................2008 535i...............2007 530i...............2008 528i................. 2007 525i
full designation..N54B30 O0..............N52B30 OL.............N52B30 M1................N52B30 UL
displacement (cc)
...........................2979................... . 2996....................... 2996...................... 2996
bore, stroke (mm)
.........................84x89.6................. 85x88.......................85x88................. ....85x88
maximum output, hp
.....................300 @ 5800................255 @ 6600...............230 @ 6500............. 215 @ 6250
maximum torque,
lb. ft.............300 @ 1400 - 5000....... 220 @ 2750...............200 @ 2750..............185 @ 2750
compression ratio,
:1.................... 10.2............................ 10.7.............................12.1............. .............10.7
injection
high-precision direct injection (HPI) with piezo injectors
..............................................mani fold injection.............manifold injection.........manifold injection
intake
Air-to-air intake charge cooling. Twin turbochargers
integrated into both exhaust manifolds.
............................................. naturally aspirated............ naturally aspirated.........naturally aspirated
valvetrain
.......... double VANOS
...................double VANOS and Variable Valve Timing (VVT)
.................................................. ......double VANOS and Variable Valve Timing (VVT)
................. double VANOS and Variable Valve Timing (VVT)
engine block
................aluminum...................alu-magnesium.................alu-magnesium................alu-magnesium
spark plug thread
................12mm.............................. ..14mm........................
.. 14mm............................... 14mm
DME engine management
...............MSD80.............................. . MSV70.............................MSV80........... .................. MSV70
All 2008 5 Series receive a new D-CAN system for quicker diagnosis than the previously utilized D-BUS. The D-CAN requires a new On-Board Diagnostics (OBD) cable which will only work with the OPS diagnostic head. Refer to SI B07 02 06 for more information.
The 2008 6 Series also receives numerous equipment and design changes as part of the Life Cycle Impulse (LCI):
Front bumper (not applicable to M versions)
Rear bumper (not applicable to M versions)
Headlamp units
Kidney Grill
Rocker Panels
Trunklid (which now incorporates the Center High-Mounted Stop Lamp on the coupe)
Tail lamps
All referenced models: Tire Pressure Monitor (TPM). Federal Regulations require all motor vehicle manufacturers to implement a system which monitors the tire pressures as of 9-1-07 vehicle production. BMW has already phased such a system into all models since 3/07. TPM needs to be reset whenever the tire pressures are adjusted (i.e. QC1, Standard Operations). Set the pressures to the values indicated on the Tire Pressure Placard found on the driver's B-pillar.
Quality Certification 1 (QC1):
New QC1 forms been developed for the additional 2008 models now covered in this Bulletin: SD92-339. The QC1 form with print date 7/07 contains the 3, 6, 7 and Z4 versions, in addition to the original form that only specified the 5 Series.
Vehicles being prepared on the GT1 for customer delivery (in contrast to those for demo service or showroom display), must have the current date on which you perform the QC1 entered in "Date of First Registration". This is usually close enough to the actual date where the car will be registered.
2008 3 Series receive a new warning indicator in the Instrument Cluster, showing that the Transport Mode is active. The warning indicator is permanently turned off upon deleting transport mode, as well as the full and successful completion of the "pre-delivery check" using DISplus or GT1 (i.e. date of first registration, Roadside Assistance, etc). Refer to SI B00 06 07 for more information.
All referenced models ordered with the optional iPod and USB Adapter will require an iPod interface cable, which must be presented to the customer. Refer to S.I. B65 29 07. Vehicles with this option processed at the Vehicle Distribution Centers as of October 1, 2007 will have the interface cable already included (placed in the glovebox). It will no longer be necessary to order the cable separately.
Floor mats can either be standard equipment on some models, or an Aftersales accessory specified by the BMW center or the customer. A new operation for the QC1 is to make certain that the floor mats, if present, are installed and their retention systems firmly anchored to the floor carpet. This should ensure that the mats maintain their positioning. Refer to BMW Centernet, Aftersales Portal, bulletin
51 07 07.
Service Maintenance:
Minor changes compared to 2007 models. N54 engines require their spark plugs to be replaced more frequently than N52K engines due to the nature of the direct-injection process utilized on the N54 engine. Condition Based Service (CBS) no longer displays the spark plug replacement interval on any 3, 5 or 6 Series.
Summary of Spark Plug Replacement Intervals:
Primary Model
Engine
Interval (miles)
Comments
328i, 328xi, 528i
N52K
100,000
No change from '07 models
328i SULEV/PZEV
N51
100,000
335i, 335xi, 535i
N54
45,000
550i, 650i, 750i
N62TU
100,000
760Li
N73
100,000
M5, M6
S85
37,000
Z4 roadster 3.0i, 3.0si,
Z4 coupe 3.0si
N52
100,000
M roadster, M coupe
S54
60,000
All Referenced Models: Engine oil should be changed at least once per year. The BMW Maintenance Program allows for this operation if a vehicle does not travel enough to have a BMW Engine Oil Service performed. This detail is listed in the respective Service/Warranty booklet. Please make customers aware of this important fact when you review an upcoming Service Appointment. Refer to SI B00 04 01.
All referenced models: At each Standard Operation, check the condition of the tires (inner and outer sidewalls; tread) as well as the tire inflation pressure. Reset TPM.
All referenced models- Reminder: The BMW engine coolant has a lifetime rating, except when the cooling system requires repairs. Drained coolant is not to be re-used. Top-up with new coolant. Refer to SI B17 01 06.
All 6 Series: CBS no longer displays the spark plug replacement interval, nor the ventilation system microfilter interval. The microfilter needs to be changed at every 3rd Engine Oil Service.
2008 Z4 and M versions of the roadster and coupe utilize a new Maintenance Checklist SD92-353.
General Notes:
The Vehicle Emission Control Information placard, located in the engine compartment, has a new format and appearance. It no longer shows the vacuum hose routing diagram, nor the model.
This placard shows the N54 engine in the 535i, but is similar for other models and engines.
All referenced models: Monroney Label information for EPA fuel economy.
The Environmental Protection Agency (EPA) is requiring changes to the fuel economy ratings for the entire automotive industry, effective as of Sept 1 2007 on all 2008MY vehicles. The new estimates are intended to reflect today's driving habits; the method had not been updated in 20 years. The new estimates are generally lower. This is why ratings on current 2008 models, with no changes to the drivetrain, appear to be "worse" than their 2007 model year versions.
2008 Service and Warranty Information booklets:
3 Series
SD92-341
528i, 525xi, 535i, 535xi, 535xiT, 550i
SD92-336
M5, M6
SD92-337
650i coupe and convertible
SD92-342
7 Series
SD92-343
Z4 roadster 3.0i, 3.0si; Z4 coupe 3.0si
SD92-345
M roadster, M coupe
SD92-346
Vehicle Data Status (Integration level) is:
3 Series
CIP/Progman V27.0
E89x-07-09-515
5 Series (9/07)
CIP/Progman V27.0
E060-07-09-515
5 Series (3/07)
CIP/Progman V25.0
E060-07-03-510
6 Series
CIP/Progman V27.0
E060-07-09-515
7 Series
CIP/Progman V27.0
E065-07-09-515/800
PARTS INFORMATION:
Under separate cover, one pack of the Quality Certification I form for the 2008 BMWs will be sent to each BMW center's Service Manager. Additional copies may be ordered as listed below:
Item
Description
Qty
Price
SD92-339, 7/07
Quality Certification I form (2008 3, 5, 6, 7 Series and Z4)
1 pack
(= 25 forms)
$4.75
SD92-353
Service Maintenance checklist (2008 Z4 and M roadsters and coupes)
1 pack
(= 25 forms)
$4.75
These items are available online at BMW TIS under Materials Ordering. Refer to bulletin B10 02 02 for instructions on how to place an order.
WARRANTY INFORMATION
2008 Model Year QCI payments will be automatically issued to BMW centers upon reporting a 2008 model year vehicle as retailed, or by placing the vehicle in service as a BMW center demonstrator or Service/Loaner vehicle. The payments, processed via a miscellaneous billing, will be based on the display and delivery check flat rates as published, utilizing each BMW center's warranty labor rate. The QCI line item on the repair order should be charged internally to the New Vehicle Sales Department.
Service
QC I
Display and Delivery Check*
Labor Allowance (FRU)
3 Series
13
528i, 535i, 550i, M5
12
535xiT
12
6 Series
13
7 Series
12
Z4 Roadster (all, incl. M)
12
Z4 Coupe (incl. M)
13
* value shown is the sum of Display and Delivery check per 9/07 KSD.
BMW Company Vehicles
Reimbursement for performing the QCI on BMW company vehicles (of any model year) must still be requested by submitting a claim through DCS using the Spot Delivery codes as listed below:
Defect Code:
11 99 99 77 BV
Labor Operation:
00 00 012
Flat Rate Units:
Refer to KSD for flat rate times.
Note: BMW company vehicles delivered to field personnel may have already received a full QCI at the Vehicle Distribution Center (VDC) which serves your region. This should be evident upon arrival at your center by the absence of the usual protective seat and door panel covers and battery main-disconnect cable, correct wipers already installed, the Monroney label is not affixed to the window, etc. VDCs affix a small orange-colored label onto the center console near the transmission selector lever which reads "QC1 already done at VDC!". If this label is found, remove it prior to delivery to the employee. Please verify that the QC1 has already been performed at a VDC on a specific vehicle by contacting your regional Distribution Manager with the chassis
SIB_000107_MY08.pdf
SI B 00 01 07
Technical Service
SUBJECT
MODEL
2008 750i (E65)
SITUATION
328xi, 335xi Sedan;
Front bumper
Headlamps
Kidney Grill
Tail lamps
Rocker panel
displacement (cc)
bore, stroke (mm)
maximum output, hp
maximum torque,
compression ratio,
injection
intake
valvetrain
engine block
spark plug thread
Headlamp units
Kidney Grill
Rocker Panels
Tail lamps
51 07 07.
Primary Model
Engine
Interval (miles)
Comments
328i, 328xi, 528i
N52K
100,000
328i SULEV/PZEV
N51
100,000
335i, 335xi, 535i
N54
45,000
550i, 650i, 750i
N62TU
100,000
760Li
N73
100,000
M5, M6
S85
37,000
Z4 coupe 3.0si
N52
100,000
M roadster, M coupe
S54
60,000
General Notes:
3 Series
SD92-341
SD92-336
M5, M6
SD92-337
SD92-342
7 Series
SD92-343
SD92-345
M roadster, M coupe
SD92-346
3 Series
CIP/Progman V27.0
E89x-07-09-515
5 Series (9/07)
CIP/Progman V27.0
E060-07-09-515
5 Series (3/07)
CIP/Progman V25.0
E060-07-03-510
6 Series
CIP/Progman V27.0
E060-07-09-515
7 Series
CIP/Progman V27.0
E065-07-09-515/800
PARTS INFORMATION:
Item
Description
Qty
Price
SD92-339, 7/07
1 pack
(= 25 forms)
$4.75
SD92-353
1 pack
(= 25 forms)
$4.75
Service
QC I
3 Series
13
12
535xiT
12
6 Series
13
7 Series
12
12
Z4 Coupe (incl. M)
13
Defect Code:
11 99 99 77 BV
Labor Operation:
00 00 012
Flat Rate Units:
SIB_000107_MY08.pdf
Originally Posted by nicke60gre' post='477809' date='Oct 4 2007, 03:39 PM
edited
520i: N46B20 - EU - 170 PS - New I4
523i: N53B25 - EU - 190 PS - I6 - Direct injection
525i: N53B25 - EU - 218 PS - I6 - Direct injection
525i: N52B30 - US - 215 HP - I6 - Valvetronic
528i: N52B30 - US - 230 HP - I6 - Valvetronic
530i: N53B30 - EU - 272 PS - I6 - Direct injection
535i: N54B30 - US - 300 HP/306 PS - I6 - Direct injection/twin turbo
540i: N62B40 - US 300 HP - EU 306 PS - V8 - Valvetronic
550i: N62B48 - US 360 HP - EU 367 PS - V8 - Valvetronic
M5: S85
520d: N47TU2D20 - EU - 177 PS - I4 - turbo
525d: M57TUD25 - EU - 197 PS - I6 - twin turbo
530d: M57TUD30 - EU - 235 PS - I6 - twin turbo
535d: M57TUD30 - EU - 286 PS - I6 - twin turbo
M5: S85
thesalboy
04-08-2015 09:13 AM
