My E60 won’t start. Please help!!
https://cimg6.ibsrv.net/gimg/5series...506c57bbb.jpeg
Hello guys, I have a 2009 e60 528i. My car won’t star and my pedal brake is very hard, it doesn’t move, I replaced the booster but still have the same problem, it doesn’t move, I Also did The bleeding but when I did the last caliper it do not bleed. And also I have a message on my dash that the ABS control system is in malfunction. All the lights on the dash turn on normally. But the car do not want to start. Hope somebody can help me! Thanks |
The only way to tell for sure what's going on is to read the codes being thrown off. If you can't move the car, can you borrow somebody's tester?
If you have a bad starter INPA will literally say bad starter. I had similar no start issue and the bad starter code was there waiting for me. New starter installed and it started.
For the hard brake pedal - that's not unusual. My brake pedal is randomly hard after the car sits overnight. Has been for years.
Originally Posted by JayArras
(Post 1600184)
Originally Posted by dcfjord
(Post 1600202)
Originally Posted by audiophool
(Post 1600207)
after pressing the brake a lot with the car up, its gonna build up pressure and the pedal will get hard. itll probably go back to normal once you get the car started.
Same issue happened to me. It was the starter.
Problem solved!!
Originally Posted by Ussebas
(Post 1600183)
(Post 1600184)
(Post 1600202)
(Post 1600207)
(Post 1600214)
I have 1 of those conventional scanners from eBay and the only code what I have are from the o2 sensor, this weekend I may have to test the starter, and I have to find what is going on with my brake system
(Post 1600215)
Yes, I’ll test the starter this weekend, but I need to find out what is going on with my brake system, but for sure I don’t want to take this car to the dealer
Originally Posted by GreaseMonkey535i
(Post 1600267)
ok guys The problem was the battery, I was trying to make it started with my e46 battery but I whent to the dealer and they told me this cars are very sensitive to the voltage. So I decided to buy the battery. Thanks everybody for the comments! |
