I got up this morning and tried to start the car.(My 525i, Pre-Sept changes) Eveything works, windows, electrical, a/c, idrive.. however the engine won't turn over. I called BMW Assist, and they transfered me to a local dealership to help guide me through it.. and the service dept was closed today. After hanging up with me, I can't disconnect the Emergency call.. anyway I can do it? It is still connected on the idrive. This is so annoying.. my car won't start, I can't hang up the emergency call.
Oh and one more thing.. my keys will not unlock or lock the car. When I try to lock it with one key it unlocks right away, the other one (The one I last used will not work at all. The dealership said something about ignition disabled? Some safety feature.. Any input? |
Like any computer. When it locks up reboot. Try disconnecting the battery. Let is sit for ~1min. Then reconnect the battery. The system should reintialize. I don't know if it will work but that is what I would try.
Good Luck, Bill |
My quick guess is a problem with the CAS module.
Here's everything you need to know about the CAS module: http://forums.e60.net/index.php?s=&showtop...indpost&p=46572 |
Here's everything you need to know about the CAS module: http://forums.e60.net/index.php?s=&showtop...indpost&p=46572 Rudy, please realize that this is coming from someone who thinks a crows foot wrench is something a veterenarian uses, but you really are brilliant :) |
