My car shakes a bit at ~75mph
I had all four tires replaced two months ago, and recently I feel my car shakes a bit at around 75mph. Do you guy have any idea? Is it because of out of balance tires or alignment?
Thanks
Thanks
My Ride: 525i SE Black Saphire, Black Dakota Leather, 116 type alloys
I'd go back to the dealer who fitted the tyres and ask them to check the balance on all 4 wheels again. I've had a similar experience in the past and I think it's because the new tyres have scrubbed in and those little excess bits of rubber from the moulding process have disappeared.
If the tyre dealer checks them and the shaking is still there, then you have a different problem which will probably need the BMW dealer to look at.
(Whenever I have had new tyres fitted, they have always told me to check the wheelnuts aagain after a couple of hundred miles - never found one loose yet, but you never know)
Model Year: 2015
Engine: N55
If the vibration is felt through the steering it is usually front wheel balance, if it is felt through the chassis it is often the rears.
Funnily enough I have the exact same problem having had new tyres fitted 500 miles ago, I'm off to get a good balancer to check it out at the end of the week.
Thanks
Thanks
My Ride: 2006 550i SMG
Sounds like wheel balancing issues. Sometimes if a wheel requires too much weight on one side to balance the wheel will start to shake at freeway speeds. The tire dealer can rotate the tire 180 degrees to see if that takes care of the lopsidedness so that it requires less weight. More sophisticated balancers will automatically tell the technician this is the case before adding the weight.
My Ride: 2003 X5 3.0----->gone
2004 Porsche Cayenne S : Gemballa front and back bodykit, fabspeed bypass pipes, Gemballa exhaust pipes, full option, 20" factory sport design rims------>gone
2005 545i 6-spd manual---->de-badged, CDV removal, Autosolutions short shift kit, resonator removal, premium package, PDC, xenon, almost full options, hardwire V1 install ....looking for mods...
2007 550i 6-spd----> Premium package, sport package, Logic7, heated everything, Rogue Engineering SSK, CDV removal, hardwire V1 install, aFe cold air intake, Custom Magnaflow exhaust....
I bet it's a balance issue. I had the same problem in my Cayenne once and after the wheel was balanced properly by the dealer the shaking disappeared
My Ride: 2005 525i Titanium Silver Metalic and 2003 325xi Jet Black with the Premium Package in both cars.
I"d have to go with the rest of the guys, it sounds like a balance problem. Its really not unique, if the tires are not balanced properly, this is one of the side effects. Good luck
chadillac2000
42
09-13-2017 11:15 AM
carid
03-06-2015 04:58 AM
