my car says it is overheating please help
Old 12-15-2009, 08:42 AM
General216's Avatar
My Ride: 2006 530xi, Silver, Black Int, Cold Weather Package, Front, side and rear M kit
Originally Posted by benjihana' post='1073492' date='Dec 14 2009, 02:15 PM
General216,
This is all speculation, but it certainly sounds exactly like my situation. Try this: when the engine has been off for a good amount of time (a few hours), open your overflow cap and leave it off. Start the car (make sure it doesn't give the overheat message, if it does, then turn off immediately), and watch for about 5 minutes. How many minutes can your car stay on just idling in a parking spot from cold without driving it anywhere? If you get backflow of coolant (a lot of it), I would suspect that your water pump went out like mine, or you have a stuck thermostat.
I had a flatbed pick up the car last night and took it to the BMW Store in Cincy. They called today - It was the Water Pump (good call). Anyway, they said they could have fixed today - $1500 later.
Old 12-15-2009, 10:08 AM
968turboS's Avatar
Originally Posted by General216' post='1073144' date='Dec 13 2009, 09:54 PM
I just went out for a quick drive (wife wanted to look at Christmas lights). I wasn't driving for 5 minutes when I got an engine overheat warning and it told me to drive moderatly. 2 minutes later the car told me to shut down right away that the engine had overheated. I pulled over and chilled for about 15 minutes. I started back home and got the first warning then the next to shut down. I pulled over again and waited about 10 minutes then drove the quarter of a mile home.
One thing we both noticed right before the warning came on is that the heater was blowing cold air. I palyed with the iDrive turning up the red blocks on the climate setting but eventually just turned the air off.
I have never had this problem, and there was no puddle in the garage when I got home. Any suggestions as to what happened? I'm going to let the engine cool completely overnight and take a look at the coolant level in the am. Has this happened to anyone else?
You obviously wont have heat if you are out of coolant. It could very well be that you have lost all your coolant. Coolant is, what creates heat in your passenger compartment via heat exchangers. This is a tell-tale sign you have loss of coolant. Check your coolant reservoir to see if you have any coolant left.
Raj
Old 12-15-2009, 10:10 AM
968turboS's Avatar
Darn, just saw your last post, 1 day too late .
Raj
Old 12-16-2009, 10:24 AM
General216's Avatar
For anyone who wants to listen to me bitch - expensive month for my car!
$1600 for the new water pump
$1000 for the car payment
$800 for the Winter Tires
Over $400 for the taxes/Tags
Old 12-16-2009, 10:41 AM
benjihana's Avatar
My Ride: 2008 BMW 550i
I'm glad I diagnosed it well, but sad that you had to get it fixed and expend the cash. Did they replace the thermostat as well?
Old 12-18-2009, 12:31 PM
General216's Avatar
I'll have to take a look!
Old 04-24-2014, 10:00 AM
code37's Avatar
what's the average approx mileage for everyone's over heating problem & OR change in thermostat, water pump, serpentine belt & tensioner?
Has anyone replaced those parts using products from
BMW Parts and BMW Accessories | Bavarian Autosport
Awest91
09-17-2022 11:05 PM
Kasmo
05-07-2019 03:30 AM
amethyste_beemer
12-18-2018 05:45 AM
Chet
152
07-08-2018 02:26 PM
james69z28
03-23-2015 06:45 PM
Quick Reply: my car says it is overheating please help
