My Baby Got Smashed Today
Old Nov 4, 2004 | 02:13 AM
  #31
PeterF's Avatar
Aaron, thanks for this explanation. I was wondering what the deal was with that and could not easily find anything via "google".
Old Nov 4, 2004 | 03:20 AM
  #32
skaffa's Avatar
My Ride: -04 530D
Originally Posted by Aaron' date='Nov 4 2004, 02:03 AM
PeterF,
Most cars have Eddy Currents flowing through the frame due to the frame being used as a ground reference.? This big issue with this car is the welding of the different materials (aluminum to steel I believe) which they need to make sure does not create a voltage offset to different areas of your frame.? That could really cause problems with the electrical devices in this car.
Good Luck!
[snapback]52483[/snapback]
I don't know much about welding, but that I know that aluminium and steel can not be welded together any normal (arc, tig, mig, mag, gas, plasm, laser...) welding. IF I remember correctly BMW uses bolting and adhesives to join aluminium and steel together. There I think is the problem: to get earthing correct in repaired area, but still avoid electro chemical corrosion.
Skaffa
Old Nov 5, 2004 | 01:41 PM
  #33
Serge007's Avatar
My Ride: 2004 525i, Jet Black, Black Dakota Leather, Poplar Wood, Steptronic Transmission, Premium Package, Xenon Lights.
[snapback]52595[/snapback]
Man, so sorry about your car
Old Nov 5, 2004 | 04:16 PM
  #34
nickferr's Avatar
My Ride: 2004 530i - Titanium Grey/Grey/SMG/Nav/sports pack/premium pack/sirius prep
Originally Posted by PeterF' date='Nov 1 2004, 10:16 PM
I took some pics of the car today, for those who wonder what it looks like when you're rear-ended by a tow truck. Note the closed gap on the door, and on the photo of the roof how the windshield was pushed up and bent up the roof a little...
[snapback]51954[/snapback]
That sucks. My 530 is the same color and it makes me cringe :'( to see yours smashed up like that. I hope everything turns out ok and you can be happy with your car again soon.
I'm a lawyer and I deal with insurance companies almost every day. The level of compassion you get depends on the adjuster assigned to your case. The bottom line result you get can vary widely depending on the insurance company. I've seen Eire, Gieco and USAA take good care of claimants.
With regards to getting a lawyer, I would say unless the insurance copmany is acting in bad faith in the way it handles your claim, you would probably be better off on your own. In your case all a lawyer could do would be to make the same phone calls (at $200.00 per hour) that you could make for free. Just be persistent and try not to get frustated. Be a pain in the a$$, but be civil about it. The results will probably be about the same as with a lawyer. Good luck.
Nick
Old Nov 5, 2004 | 07:03 PM
  #35
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by nickferr' date='Nov 6 2004, 02:16 AM
I'm a lawyer and I deal with insurance companies almost every day.? (...) Nick
[snapback]53097[/snapback]
Old Nov 6, 2004 | 03:59 AM
  #36
nickferr's Avatar
Originally Posted by Iceman' date='Nov 5 2004, 11:03 PM
[quote name='nickferr' date='Nov 6 2004, 02:16 AM']I'm a lawyer and I deal with insurance companies almost every day.? (...) Nick
Attachment 3083
[snapback]53131[/snapback]
[/quote]
Yeah, I know.
Old Nov 6, 2004 | 06:51 AM
  #37
BMW#7's Avatar
Originally Posted by PeterF' date='Oct 30 2004, 03:54 AM
Got rear-ended by a flat bed truck today --
Really sorry - been through similar experience, but not a truck, just a car that rear ended me. Main thing is that you are OK.
In SA we have to take the cars to Approved BMW repair agents - it is amazing what these guys can do. I had very good service and most of the work was excellent.
However, one bit of advice I can give you, is to really check the paintwork consistency under several different light sources and angles.
Old Dec 5, 2004 | 10:32 AM
  #38
IrishEyes's Avatar
My Ride: Collected Sept 2009 - BMW E90 M3, Silverstone II, Novillo Black leather, 19" M Double-Spoke alloys, High Beam Assist, Electronic Damper Control, Voice Control, PDC, USB, DAB, High Gloss Shadowline, Sliding armrest, Trim Finishing in aluminium grey.
Hi and WOW. When I saw the pictures, instant cringe. It looks like the only thing not bent was the ignition key. With a thump like that from behind, I hope u had the head-rest adjusted correctly. And I take it you are still feeling physically OK.
I was just cruising around the forum and saw the pictures. I think the last post (no pun intended if it is for the car) was around November and was just curious to find out how it is turning out. Replacement or repair. Looks a mighty lot of damage to repair. I would think the cost of repair would need to be looked at against it's used value and not the sticker price as new on the forecourt. This will probably determine if it is beyond economical repair.
Best of luck.
Old Dec 5, 2004 | 10:37 AM
  #39
Iceman's Avatar
Model Year: 2013
Welcome aboard, IrishEyes !
Old Dec 5, 2004 | 11:18 AM
  #40
geneclark's Avatar
PeterF,
Glad to read that you're OK! Being hit from behind is very dangerous. I'm not a doctor, but I really think that it's important that you have a specialist look for potential neck injuries. I know of accidents at low speed which (many years later) have had consequences for the person being hit from behind.
