My 535 needs a new battery, any recommendations?
My Ride: 535i
Model Year: 2011
The car is more than 4 years old and and because it doesn't get driven every day, the time/date and trip odometer Zero out every so often, probably due to a weak battery. This was confirmed my the service manager at the local dealership.
Sound like a new battery is in order. I called Sears and they have a couple different DieHard's, and I heard that Interestate makes a good one too.
Any recommendations?
My Ride: 2021 BMW 540i XDrive Bluestone Metallic on Ivory White Napa Leather. Packages: Executive, M Sport, Parking Assistance, Luxury Seating, Shadowline. Options: M Sport Brakes with Blue Calipers, Body Color Rocker Panel Blades and Spoiler, Heated Steering
Model Year: 2021
My Ride: 2008 550I,Space Grey,Hud,Cold Weather,M - Sport, matched GP Thunder headlights and Fogs,,Smoked Badges, Night Vision, Heated Seats,Rear Sunshades, Aux Audio, SAT, NAV, Black Grills, Sprint Booster, Dinan Cold Air, Stage 2 Dinan Software.....More to come soon
Hmmm...did you have them test it with a tester? Sometimes a nice full recharge will take care of it. Go to Pep boys and have them test it, then you know what to do. Oh yes despite what Pep boys guys tell you "they do not have a battery that is suitable for e60" it might work for 3 months and then it craps out. If you do a search you will see my opinion about batteries in general.
Good luck with your quest for battery!
My Ride: 535i
Our E60 had the same symptoms with the clock/date and it was driven 400 miles/week, 95% freeway. The vehicle wouldn't start one day... two soon to be hungry toddlers in the car and 50 miles from home. Turns out it was a bad cell in the battery (3 yrs old). BMW covered it under warranty but I think only because the computer showed it had been driven regularly. Kinda irks me the BMW has this "advanced" charging system that needs to be programmed to the AGM battery but it only lasted 3 years. My Lexus has a 7 year old lead acid battery with a conventional charging system. I'm looking at changing the battery now though as 7 years is pushing it. But the OEM Lexus battery has been abused far more than the BMW AGM battery, it sits running an onboard fridge 48hrs at a time.
You'll need to decide if you want to deal with the battery registration issue.
Best of luck!
Jim / crewzer
Best of luck!
Jim / crewzer
My Ride: 2015 535D M Sport
Duralast from AutoZone works great. No registration. No problems after more than 2 years. I think registration is a bogus "requirement" unless you make a significant change in battery technology (conventional to AGM) or capacity.
