Musty odor from AC vents
My Ride: 2011 550i M sport
Hello all. I was hoping you could shed some light on my problem. For the last 1-2 weeks there has been a musty odor coming from the vents. Never before, but started after the weather got cooler here. Is this temporary or is there something wrong with my system...seems abrupt and coincidental with the weather change. Anyone have info. I am still covered under warranty and maintenance so Im okay from that standpoint, but was wondering if this is something that does not need to be dealt with by dealer.
Thanks
2005 545i with smg tranny, nav, hud, comfort seats, etc
Thanks
Thanks
Thanks
Originally Posted by mag75' post='738919' date='Dec 5 2008, 05:30 PM
I had/have the same issue. I took it to the dealership and they said the microfilter was responsible for the smell....BUT since the stupid idrive said I didnt need a new one, they couldnt replace it....so they cleaned it, sprayed some stuff on it and that seemed to do the trick.
Thanks. I also found an SIB online that dealt with this issue thanks to a previous post here the other day. I guess thats the only way. Dont think they will change the filter as my i drive says its still good and they are trying to sell me an extended maintenance plan (mine expires end of may 2009)
Originally Posted by andy535xi' post='738917' date='Dec 5 2008, 05:29 PM
You have to tell the squirrels living under the hood to start using deodorant ... j/k I don't have that problem and can't suggest anything sorry ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I asked and they declined, citing religious/cultural beliefs
My Ride: 04 530i Space Gray/ Black Dakota Leather interior with SMG, Sports Package+ Paddle Shifters, HUD, NAV, Premium Package, Multi-Contour Seats, Xenons , Logic 7.
I saw a spray at my dealership that removes odor. It's supposed to be good.
My Ride: 2007 E60 550i
I had a similar issue with my 550i and took it in for service. The guys jokes that they don't warranty smells, etc, but were clearly avoiding the issue.
I bought new microfilters from www.germanfilters.com, did the replacement myself and cleaned out the existing filter boxes of leaves, junk, and dirt.
The other issue that is common with these cars is that shutting off the car in recirc, or that using recirc all the time, and not auto, will build up moisture in the system.
Anyway, the above worked for me, and I haven't had a musty smell since.
My Ride: G30 530i M-sport
Model Year: 2018
The musty smell is most likely from residual damp that ends up sitting in the microfilter after running the a/c in warmer air. What seems to work for me is to switch off the a/c but leave just the blower running for the last 1/2 mile or so of my drive home to clear the artificially cooled air out the system before shutting the car down. Seems to work 99% of the time.
