Mushy Brake Pedal
My Ride: 2004 530i Silver Grey, Grey Dakota Leather, Premium, Adaptive Xenon, L7.
Mods: Sprint Booster V1, 8000k GP Thunder Headlight, 8000k HID fogs, LED Interior, LED License Plate, Rear Red Reflectors
Wish List: Mtech Kit, Style 172 Rims, KSport Coilovers, Shadowline Trim.
So, I have had a mushy brake pedal feel for awhile now. Its not a stiff pedal like it should be and kinda concerns me sometimes. I get adequate stopping but think it could be better. I have all new pads and rotors within the past 15k miles with plenty on life still left in them. Did a brake bleed last year.
Would a brake bleed possibly fix this to ensure all air out of system? Or can it be something else? I want a stiff brake pedal that feels solid and reassures you that the car will stop. Thanks
My Ride: F10 M5
Model Year: 2013
wow more bad advice. Bleeding the system does nothing for a "mushy pedal" You either have a really small leak somewhere which is the less likely cause or you have a bad master cylinder-the more likely.
Bleeding will do nothing-provided you changed your brake fluid atleast once every 2 years and the pads and rotors are good-the only thing at this point is the master cylinder and it is not properly regulating brake fluid pressure throughout the system-needs replacing
My Ride: 2006 BMW 550i CPO bought in Jan 2009
bleeding removes air from the system. Air compresses, giving you that mushy feel. There may be other problems causing the mushy feeling, but bleeding would be the first thing to try, quick easy and cheap.
bestofthebest
03-28-2016 02:47 PM
