MPG
Old Dec 21, 2005 | 06:18 PM
Jerzguju's Avatar
My Ride: 2005 525i: Mystic Blue, Auburn Dakota leather Premium and Winter Package, Xenons
Ok so i reset the MPG today under the Car Data section... As i drove i kept the RPM's below 2 and below around town...the heater was on low (the lowest possible) and i was getting an MPG of 14.4....Does anyone know what the deal with that is...I was below 2 RPM's the whole 15 minute drive and I got 14.4 ?!?
Old Dec 21, 2005 | 06:26 PM
znod's Avatar
How did you measure the 14.4? And, below 2k is not necessarily the ideal way to measure MPG. Finally, you may need to measure for more than 15 min. to get a good read across your more or less normal driving habits.
Try restarting your mileage calculator and just driving normally while watching your instantaneous mileage indicator. Try to drive so that you keep the instantaneous indicator well above the mpg figure you are trying to, or think you should, acheive as much as you can, but especially once you get more or less up to speed. And, it still might help us if you explained exactly how you came up with the 14.4 value--i.e., specifically what procedures you folllowed.
Old Dec 21, 2005 | 08:50 PM
Freewilly's Avatar
My Ride: 2013 535i (White with Oyster Interior. Premium Package, Navigation, Technology Pacakge, Park Distance Control, and Rear View Camera)
525i should average about 25-28 MPG.
Old Dec 21, 2005 | 09:37 PM
EBMCS03's Avatar
Below 2K? you might have been in too high of a gear and lugging the engine more than it should thus burning more gas just to struggle to keep the car going. *just a thought*
Old Dec 22, 2005 | 04:00 AM
JDN's Avatar
JDN
As EBMCS03 indicated, it's not the RPMs alone that govern favorable fuel mileage as much as the gear you are in and the position of your foot on the accelerator. Acceleration, coasting, grade, speed, wind direction, tire inflation and other factors enter into the equation.
Try cruising on a level road at about a constant 40-45 MPH in top gear with the foot on the accelerator as if there were an egg under the accelerator pedal that you are trying not to break. Then punch the reset button to reset the gas mileage computation. You should immediately see a number that would make most of us smile. Don't get too happy, though, because it will average down as you continue driving.
You might also pay particular attention to the instant gas mileage needle and see how it reacts under different driving conditions. The more time the needle spends on the left, the better the average. (Sorry, Rudy.)
Old Dec 22, 2005 | 05:57 AM
tnjet's Avatar
Ouch! I was concerned that my 545 would be in that range. So far I average just at 30 on the highway and just under 20 with a mix of highway and city driving. Only had the car 4 weeks, but so far it's been great.
Old Dec 22, 2005 | 06:25 AM
SolanNo1's Avatar
My Ride: Alpine White/Biege 545i, CWP, Nav, Active Steering, Auto Step ordered 2/1/05
I usually average ~16 on my mostly city driving. Surprisingly, the cold has not reduced my consumption.
Old Dec 22, 2005 | 06:36 AM
Ricracing's Avatar
Something strange here, but bare in mind that the car works at it best around the max torgue rpms,
and that would mean around 2,500 - 3,500 rpm.
I was yesterday driving around southern Finland (about 300 km or 187 miles) delivering some Christmas presents to my customers.
The roads where exremely slippry, tempatarures around -10 C (14 F) so I was driving easy and not faster than 110 km/h (70 mph) and the iDrive showed a avarage consuption on 7,5-7,8 l / 100 km/h (30-32 MPG).
The rpm was most of the time a bit over 2.000 rpm.
Usually the car gives about 20 MPG in the winter time and city/suburban driving.
Old Dec 22, 2005 | 06:46 AM
Ray Hull's Avatar
My Ride: '04 545iS 6 spd, bought new via eBay, 11/05; Blk/Gry, Cold, L7, PDC, BMW Rear seatcover for pets. First "Bumwa" was a new 1971 2002. High performance 5s since 1987. Beamer motorcycles too, currently on an 07 BMW K1200 GT; also a Moto Guzzi 1000 SP III.
That's exactly what mine gets (at 6 weeks and 3K miles); thx.
In the subject situation, everyone is correct: around-town driving is not a proper measurement. I'd suggest setting it to zero 8 am or whenever, and driving for a routine day or two, and then checking it at 8 am two days later. That will give an avg daily mileage. Then you can check trips or just around town to see how it's weighted.
Oh, and "heater" operation doesn't matter; air conditioning (compressor load) will.
Keep us posted,
Ray Hull
Old Dec 22, 2005 | 07:53 AM
sicce's Avatar
Suggest you look in the iDrive and set the units of measurement to UK gallons - should fix the problem hopefully.
