Every time that I listen to the FM or AM radio for few minutes all my stations disappear from the scale. The only station that stays on the scale is the station that I listen to, the only way you can get the stations back on the scale again is to exit from the radio menu and go to the main menu and go back to the radio menu again. Did anybody else experience this before??? :help:
I don't think my software was ever uptaded.
My car is going for service this Friday, so maybe I will also tell them to uptade my software. What problems CIP 19.01.01 corrects???
Thanks for your help vnod
Do you have NAV? maybe its this?? Sounds similiar... but then again you said you dont have CIP 19. :think:
SUBJECT CCC: Radio Station Preset List Intermittently Empty MODEL E90, E91 (3 Series) with SA 609 CCC-Navigation E60, E61 (5 Series) with SA 609 CCC-Navigation E63, E64 (6 Series) All vehicles produced from September 2005, or older vehicles that have been updated with CIP 19.1 or later. SITUATION The stored radio station list (presets) is intermittently empty. The radio stations stored are not displayed in the CID (Central Information Display). It is still possible to change the stations using the steering wheel buttons. The audio still functions correctly. CAUSE Software error in CIP 19.1 or later. PROCEDURE Do not replace any parts. The station list will be displayed again if the audio source is changed and changed back again (e.g. from FM to CD and back to FM again). If changing the audio source does not provide a solution, program the complete CCC again using the "software update" path, then carry out a 30 minute battery reset and then perform a complete vehicle encoding. This service information will be updated once a software solution is available. |
