Misfire lead to lots of smoke, gas leak, now car won’t turn on :(
My Ride: 535i M / X-Drive
Model Year: 2010
Engine: N54
H
Hi,
So apart from the engine overheating issue I was facing for a few weeks.. I decided to go take the car back from my local Indy since I’ll have to wait to get the OEM water pump(if that’s even the case with my overheating).. but the other day I decided to top up on coolant.. half of a normal water bottle in water and the other half coolant.. soon as I started the car I noticed the “rough-ness” and ran pro-tools on the car, it was reading the following error codes:
Ok so I will attach a picture of the coil that was used in cyl 6 and how it looked.. then, I went and put 20$ in gas but decided to put 94 octane from Petro-Canada (don’t ask why, I normally always put 91.. not sure if it even matters with this but I read someone say they had exact problems as me, and went as far as blaming the fact they used Petro-Canada’s 94 octane gas and that was their problem apparently..?).. and what are the odds that my problems matched that person’s problems, and the one time I put oct 94 too? then I noticed a lot of smoke coming out of the exhaust while I drove two mins down the road.. so this is where I noticed Cyl 6 was still misfiring when I ran pro tools again.. stopped and swapped out the coil again with a diff one i had.. but even after resetting the codes it instantly gets picked back up (cyl 6 misfire) and then I noticed a little small leak of gas from the exhaust and then I drove home (which is only a minute down the road) and this whole time I noticed the gas tank go from 125km in range, to only 30km in range, in the two minutes that I drove.. literally.. but once I turned the car off at home, it wouldn’t turn back on anymore.. tried unplugging the IBS and even went and replaced the battery for a brand new one but no luck.. it cranks but won’t start.. then I noticed the car was showing dashes for the gas so it was completely empty on gas too.. so I grabbed a tank and put ten bucks in it and topped up that gas in the car too and still no luck?
Now my bro(who owned the car before me, said he had a very similar problem before and it was due to injectors 1,2 & 5 and it was apparently leaking gas into the cylinders or whatever..?) so he changed those injectors and kinda makes sense that 4 and 6 weren’t replaced and those gave off error codes, with cyl 6 misfire coming back on right away after I cleared the codes.. any insight on my issues would be really helpful.. I really f***ing hope(excuse my language
lol just extremely frustrated) that it’s not the fuel pump needed to be replaced, especially since I prob still gotta replace the water pump.. even though the water pump’s error code I would get ONLY after the second iDrive warning for overheating would come on(which #1 warning being the yellow one warning to drive moderately, and #2 would be the red warning where u basically lose all power) and only then, I’d get error code 2E83 - electric coolant pump, power-reduced operation..
Other error codes I got at random times with the overheating issue:
2C39 - oxygen sensor before catalytic convertor; Dynamics
2F83 - Engine switch-off time, instrument cluster timer - DME timer, comparison
2F81 - Engine switch-off time, instrument cluster timer - DME timer, comparison
29F5 - catalytic-converter conversion 2
29F4 - catalytic-converter conversion
2A7C - variable camshaft timing control, intake, cold start
3100 - boost-pressure control, deactivation
And ALSO (smfhhhh) before all these problems.. I got these error codes every now and then (but used to use iCarly for scanning and coding back then so might be a b it diff than Pro Tools)
2A7C - VAnoS, intake, cold start
9C6C - 12V stepper motor / reference switch / 12V supply peripherals / Nozzle heating / Monitor AUC supply / Reserve 4 / Current sense for AUC supply / heating / 12V output peripheral / steering column adjustment motor
With protocols the same error code is:
9C6C - washer nozzle heating
9C55 - PTC heaters / Fresh air damper motor / Fogging sensor / Fresh air motor
2F83 - Engine shut-down time, time counter combi - time counter DME, comparison
With protools the same error code is:
9C55 - fogging sensor
Then I’ve always had
54C6 - oil wear (this is for the dif oil if I’m not mistaken)
So that’s everything.. sorry for the book I had to write/length of my post
I only said all of this to break it all down for you guys, in hopes of having my main issues I’m stuck with right now, resolved by having some1 with more of a brain than myself, shed some light on what my problems are![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
Thank u so much for ur time, and again, I’m really sorry for such a long and boring post
if any1 has any idea(S) for me on where to start plz, it would be greatly appreciated
I only got the car like a month and a half ago from my brother, and have had nonstop problems from the day I got it lol
260-270k km’s on it lol engine was replaced at about 140clicks
Hi,
- 29CD: combustion misfires, cylinder 1
- 29D2: combustion misfires, cylinder 6
- 29D9: misfire at low tank fill level
- 29CC: combustion misfires, several cylinders
- 2B2C: Fuel high pressure, plausibility, cold start
Killaduce (07-24-2021)
Model Year: 2010
Engine: N54
I haven’t drove the car in over two weeks
Model Year: 2010
Engine: N54
anyways I am a rookie to this shir.. and sadly, all my issues began after I started messing around with trying to code stuff in the car lol maybe all my sh*t started from that too
thanks for ur advice though
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
So you started coding and everything start messing up? Did you know what you were doing while coding (following instructions form somewhere)? Just factory code the car and start over if you think it has to do with an error in coding.
Killaduce (07-25-2021)
Model Year: 2010
Engine: N54
Ricapar
11-03-2011 04:51 AM
