Miro 111's what size hub rings? Please help.
My Ride: 545i
Since I got my 19inch Miro's installed, the tire shop just can't seem to correctly balance them. Took the car to BMW, they said the hub ring is too thin, they were able to move the wheel up and down while on the hub, (too much play) so I went back to the tire shop and they put metallic hub rings that are a bit thicker, but still the same issue.
Here's what happens... up to 100Kmh all is ok, at 115kmh the steering wheel starts to shake, at 120 the steering wheel is ok but the entire car is vibrating especially when I accelerate.(this could be due to the rear tires not balanced properly)
This happened to me when my winter tires were out of balance, and when BMW balanced the tires it was perfect!!
Now, those of you who have 245/19/35 fronts and 275/19/30 rear, when is the thickness of your hub ring so the rims fit perfectly without any play? BMW 545i 2004 non sport model.
Thanks in advance
Thanks in advance
My Ride: 06 530i
Same thing was going on with my my 20" Miro 111's that I bought off of a member on here. They said that it was the actual tires being "out of round" whatever the hell that means. But they speed balanced them up to 120MPH and somehow got them within spec. But I found it was very odd.
My Ride: 2006 BMW 550i
i have the same problem. i even took my wheels to get rebalanced. i assumed it was the thin metal rings. i bought a plastic set of rings of ebay. havent installed them yet.
74.1mm to 72.56mm
http://www.ebay.com/itm/390210039855...ht_2780wt_1139
74.1mm to 72.56mm
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
I have 20" Miro 111 staggered and I haven't experienced anything like this. I have taken this car up to 100mph/160kph several times and I cruise at around 75mph/120kph on the freeway with no issues. I hope I don't have any in the future. My tire guy said that it did take a lot of weights to balance the wheels though.
