messed up while coding CAS
Old Jan 26, 2024 | 06:12 AM
styngeris's Avatar
My Ride: E60
Engine: M54
Exclamation messed up while coding CAS
i tried to code lci headlights to my car and i messed up that every light has a failure.
i did it in ncsexpert, typed #0907 in vo/fa then chose cas ecu and instead of hitting change job i hit execute job.
could anyone help me?
Old Jan 26, 2024 | 06:28 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Just default code it from the frm or you can create a factory profile and just sgcodieren the CAS
Old Jan 26, 2024 | 07:19 AM
styngeris's Avatar
My Ride: E60
Engine: M54
could you give me more info on that?
i loaded my chasis selected CAS, processed the ecu, chose CAS again then chose SG_Codieren, and then i just got an error in CABD
Old Jan 26, 2024 | 07:23 AM
You can't code the CAS from CAS if that's what's messed up that doesn't make sense. Do you have teamviewer and are you connected to internet?
Old Jan 26, 2024 | 07:27 AM
styngeris's Avatar
My Ride: E60
Engine: M54
yeah i do
Old Jan 26, 2024 | 07:28 AM
Send me info and I'll remote to you real quick
Old Jan 26, 2024 | 07:51 AM
Let me know if it worked after you let the car sleep. It was factory coded back to original FA
Old Jan 26, 2024 | 08:52 AM
styngeris's Avatar
My Ride: E60
Engine: M54
unfortunately the failures are still there, but by any chance could i have reset them in to factory settings in the first place and the failures are due to the retrofitted headlights?
the headlights are lci non adaptive halogens
Old Jan 26, 2024 | 09:31 AM
If you have not coded what you retrofitted you will have errors until it's coded
Old Jan 26, 2024 | 09:35 AM
styngeris's Avatar
My Ride: E60
Engine: M54
yeah i probably reset the previous owners code
thank you so much for taking time out of your day just to help me out
