Members with high mileage E60 N54
Old 05-22-2012, 12:20 PM
tonyb635's Avatar
Originally Posted by NYAWE60
You have cracked turbo lines. I cannot believe that a car of this caliber has cheap rubber hoses instead of steal braided lines. I had this issue, the parts are less than $30. The charge for labor was $375. But my car ran like a champ after. Do not be reluctant to fix this issue, it WILL get worse.
Do you know where exactly the turbo lines are? Is this the rubber charge air pipe? Not quite sure what to look at for ordering the parts.
Old 05-23-2012, 11:04 AM
NYAWE60's Avatar
My Ride: 2008 535i, Sport, Premium, Navi, Comfort Access, USB/iPod Bluetooth, Cold Weather Package, Bi Xenon Cornering Headlights
There were a series of them. One of them was by the wastegate/turbos. There is another set by the exhaust under the trunk. They literally disassembled my entire trunk and showed me the vacuum line that was by the rear muffler. That one was bad too. Honestly, it didnt look too much like a DIY job, but then again I don't know the N54 motor like that. It's not like my supra where everything was laid out very simple. This motor has tons of lines and wires going from here and there to god knows where. Take it to a turbo shop they maybe able to replace the lines for significantly less. In the end I paid $400 to get it all done. Good luck and let us know what happens.
Old 05-23-2012, 03:50 PM
mjcalabrese's Avatar
I have a 2008 535i that just past 101,000 miles. No problems except for the HPF changed under warranty. Doing some preventative maintenece this week. Changing the serpentine belt and tensioners, Upper and lower radiator hoses, transmission fluid and rear end oil.
Old 05-23-2012, 08:37 PM
louisrai's Avatar
My Ride: 2008 BMW 535i Silver - E60
85000 miles here, 08 535i. Got battery replaced, water pump, thermostat replaced, currently with oil leak and windshield wash pump leak. what you think?
Old 05-23-2012, 09:05 PM
sahiljain22's Avatar
My Ride: 2008 535xi
DIYs would be awesome .. please please please
Old 06-14-2012, 09:39 AM
jim7498's Avatar
My Ride: 2004 530i
141,000 miles. Only problem I had was a faulty starter, however i'm starting to leak transmission fluid.
Old 06-14-2012, 05:43 PM
shebuilt's Avatar
My Ride: 2007 525i 6 spd ... [IMG]http://i970.photobucket.com/albums/ae188/shebuilt/e60/DriverSide1.jpg[/IMG]
166K miles on my 07 525i and had to only change the thermostat! Stuck open. No issues and praying to God none to come!
Old 06-17-2012, 12:24 AM
JustNick's Avatar
My Ride: '04 545i
Geez, some of you guys are really stacking on the miles and see that makes me confident! I just got my 545i with just over 90k on the clock. No issues with it at all, but then again I just bought it. I did have the active steering thing come up but I was able to reset it thanks to the search bar!
Good luck !
Old 06-19-2012, 12:10 AM
amerzakaria's Avatar
im having E60/2004 .. with 239,000KM running great and engine sound so smooth ... and i have a customer he has 645 with 350,000 km i was like ( WOW )
also there is 740 1995 E38 .. 490,000 KM :S still running he is almost 500,000
chadillac2000
42
09-13-2017 11:15 AM
Stranger12
04-05-2015 10:42 AM
Steve Gill
E60 M5 Discussion
03-20-2015 03:54 AM
ZeZe
10-15-2003 12:58 PM
08-12-2003 11:41 AM
Quick Reply: Members with high mileage E60 N54
