Mechatronic rebuild
Old Jan 4, 2020 | 08:12 AM
SMOKESHOWIN1's Avatar
My Ride: 2008 535xi Monaco blue metallic/beige sport options
Default Mechatronic rebuild
Hey everyone; 2008 535xi 102,000 miles. Tranny isn't shifting smooth. Upshift, & downshift. I can get the solenoids, & all seals for under 400 bucks @ fcpeuro . I'm in the Buffalo,NY area. Anyone know where I can get the service done & adaptations set after the service. I'm brave enough to do the service, but have no clue on downloading the adaptations. Thanks...Greg
Old Jan 4, 2020 | 08:24 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
At 102k you should only need a fluid changed and adaption reset. Are you having trans codes thrown. If not there's no need for the solenoid change
Old Jan 4, 2020 | 04:38 PM
Did a fluid(zf6), & pan/filter change last spring. Thinking the progression should just be seals this time, which shouldn't require the adaptation download. However, just thinking "knock it out", while I got the mechatronic pulled out. So, do seals & should be good. Man I love this car!
Oh, & no codes!
Old Jan 4, 2020 | 06:18 PM
Yes if you have no codes there's no need to do solenoids. I've been doing a fluid change every 50k since my VB was rebuilt (I had a lot of codes and trans going into limp mode). Resetting adaptions is easy through INPA. I always reset adaptions when I change the fluid.
Old Jan 5, 2020 | 05:38 PM
Hey Sean; Thanks for the info. Where do you get INPA?
Old Jan 5, 2020 | 06:43 PM
Take a look at the forum below. This is were you will find all coding information
Old Jan 8, 2020 | 04:58 PM
mrshaky's Avatar
My Ride: 2010 E60 528i
Here's a great resource: Genuine ZF Parts
They can rebuild your valve body and send back to you so no coding required.
PaoChe
Feb 2, 2020 05:44 PM
psam550
Jun 26, 2014 04:41 AM
elie7
Feb 25, 2013 12:51 PM
Redneck
Apr 2, 2010 11:38 AM
bmwroger1
Feb 1, 2010 03:54 PM
