Mechanical Tensioner(s) - M54 - Torque Q?
My Ride: E60 M54
Model Year: 525i 2004
Hi Guys, I have searched in different places and cannot find the right tightening torque for the bolts holding the two mechanical tensioner pulleys on my M54 E60 engine. I can't find this detail in TIS or Bentley manual (unless it is supposed to be derived from generic bolt torque spec)
I have attached the pictures of the new pulleys I am trying to install, but before I go ahead, I need to confirm the tightening torques on the bolts that will be holding these two new babies. From the look, it is a silver bolt 8.8 (probably M10, not sure until I pull it out). So, many of you out there who have done these pulley replacement, I would appreciate if you can share your tightening torque for both the AC Tensioner and the Alternator/Engine belt tensioner (pictures attached)
Thanks in advance.
Thanks in advance.
My Ride: 2010 550i M Sport
All M54 pulleys have the same torque 45 Nm ( 33 ft.lb )
M54 alternator - pulley crazy torque 44 Ft Lb - Bimmerfest - BMW Forums
My Ride: E60 M54
My Ride: E60 M54
Digged a little more into the BMW TIS and found these;
Alternator/Engine mechanical pulley - 45 Nm
AC Tension pulley - 35+/-5 Nm
bestofthebest
03-28-2016 02:47 PM
