MAYBE IM PARANOID... But I think something's wrong with my BRAKES!!!
My Ride: 04' 545, 6 Spd Manual, Blk Lthr, Sport Pkg, Sport Sts, Logic 7, Cold Wthr Pkg, Full L.E.D. Interior, Red Eng. Cvr, Mtech Front Bmpr, M5 Spoiler, Matte Blk Grill, Red Caps, Slttd & Drlld Rotors, 20
So here it is in a nutshell I recently purchased R1 Premium Rotors and Hawk Pads from Acute Performance since most on here seem to like them I thought I'd give it a shot (previously had oem pads and drilled/slotted rotors). I got the rotors and pads installed friday and drove home from the shop. It was rush hour didnt want to risk having to stop at lights etc. after bed in so I went str8 home and drove easy. This morning I decided to go out and "BED IN" the new setup after following hawks directions and driving the car to let the brakes cool off. I come back to this?... I could be wrong but to me it seems as though these brakes got too hot and some how this rotor is burnt, Im not sure if thats even possible but this doesn't look right. I could be wrong though anyone ever seen this before?.... BTW I contacted Michael (Great person to deal with) he said he would forward the pic to R1 but its the weekend I wont get a response till Monday I just want to see what some of you guys think.
Depending upon how hard you stand on the brakes during the bed-in, you'll need 3-7 minutes cool down running at 60 mph + (you have to have air flowing over the rotors to cool them) between braking.
The other thing you want to look at is if the caliper(s) are hanging up. If the pad constantly rides against the rotor with pressure they will definitely overheat. The slide pins might need to be lubed.
Either way, once the overheating is corrected, unless the rotors are warped, the discoloration will quickly wear off with use.
My Ride: 540i
Model Year: 2017
My rotors had a blueish tint after bedding in also. Means you got them hot like you're supposed to. It wore away after a few hundred miles. Very happy with my R1 rotors and Hawk pads
Yea thats exactly what Im talking about... From what I can see the pad is touching the rotor, should they flatten out over time?
Im talking about the gold look that they have... How long before your pads felt good when stopping?
I didnt have any discolouration though heres how they looked the day they were installed and bedded!
https://5series.net/forums/vendor-cl...5/#post1458413
i remember looking at the new pads and noticing that there were areas that werent touching the rotor, over time the pads will wear flat
