Manual trans, stubbborn to first
My Ride: Just gone-520d m sport- Jet Black- Dakota Leather black- AluCube interior,
On order- F10 520d SE-Titanium Silver
From time to time I've found first gear difficult to engage in my 520D MT. I spoke to a service agent and he advised this is usually because the floor mats creep up under the clutch pedal preventing full engagement. I never really bought this but the issue wasn't sufficiently annoying to push it. During a recent particularly cold snap the problem has recurred. I've removed the mat altogether but there is no improvement. I found it easier to to to first via second rather than for the lever from neutral to first, if that makes sense.
My trips are generally very short <5 miles so could this stickyness be due the transmission oil not getting sufficiently warm? Or could it be a sign of something more ominous?
I use to put the first in via the second gear too. Works well
Originally Posted by Anzafin' post='1088271' date='Jan 11 2010, 02:21 PM
This has been discussed here before and it's the same with my 530d. Occurs especially on colder days, but I don't think it would be a sign of anything bad.
Model Year: 2010
In winter, I shift into 2 then 1 before I let out the clutch. Transmission is just too cold. After some driving, the manual transmission is easier to shift.
Normal vehicle operation. Every single manual transmission I've ever driven acts this way, from a lowly Nissan Sentra to various MB models to all types of BMW transmissions. If it goes in after either a 2nd pump of the clutch, after going into 2nd, or after releasing the parking brake and letting it roll a half a foot, it's normal. Getting worse when it's cold is also normal. I don't think you'll find much difference with a CDV swap, that only affects the engagement action of the clutch. If you have to take truly heroic measures to get it into gear, something is obviously wrong, but it doesn't sound like that's what you're experiencing.
Good luck!
Good luck!
My Ride: 2006 525XI, Jet black on Dakota beige. Premium and winter packages. I consider myself a purist and intend to keep my car absolutely stock and shiny.
2008 328I Convertible, Sapphire black on beige interior. Premium package, NAV, iPod adapter.
Retired: 2002 325I, Titanium silver on black leather. Premium package. Absolutely stock and proud of it.
I haven't driven a manual in a while, but in the old days, I would have suggested that you may have a bad 1st gear synchro. At least this is what was wrong with my '86 911, but manual transmissions have changed since that car and I am out of the loop. G/L
My first gear has done that a couple of times...just go back to neutral and then into first and
it usually goes in....
Don't know if it's related...but my second gear is crunchy sometimes when shifting in a turn... and on rarer occasions when going straight..
My Ride: 2005 Jet Black 545i w/ sport pkg, nav, HUD
Originally Posted by v_therussian' post='1088733' date='Jan 12 2010, 12:35 AM
Research CDV (Clutch Delay Valve)
If you really wanna resolve this issue, you'll find the right answers with the info I just gave you
It's the synchros which sounds like it's normal from what you are describing.
Will
bestofthebest
Mar 28, 2016 02:47 PM
