When I bought my car in December it had 3 Riken Raptors and 1 Dunlop on the front left. The Raptors look pretty new and still have the little things sticking out of the side walls...
Well after my latest oil change the singe Dunlop on the front left show the steel belts on the inside of the tire. Bought a brand new Riken online and had Sears AutoCenter(for a simple tire change) replace the tire, put the new tire on the right rear, and do a alignment. (Which they talked me into.) (There was NO vibration before I did any of this.) Now the car is vibrating like crazy. I have the print out from Sears showing the E60 specs for aligment and they made some adjustments to the left side. What did they do and what do you think the problem is? I'm taking it back to Sears this afternoon. |
3 Riken's and one Dunlop?? Sears and BMW?
Good luck. The chain brakes always at the most frailty spot. |
Good luck. The chain brakes always at the most frailty spot. Can someone please give me some advise. |
Did they use Hunter Road Force equipment for balancing? Hunter Road Force will simulate real world condition.
I'm leaning toward the balancing problem as oppose to alignment issue. |
Well, before I had to read what you all just said I went back to Sears. They balanced all 4 tires and it seemed to have fixed the issue. You all are very right!
I've read good things about these Riken's... I always put Michelin's on my cars as well. Got 90k out of a set on my Hyundai Sonata. I just don't want to throw away perfectly good tires! I doubt Sears does road force balancing. They said I had a slightly bent rim... don't all rims get bent after some time? |
