Major oil leak - 5Series.net - Forums
Sponsored by:
Sponsored by:
Thread Tools Search this Thread
Old 12-14-2017, 04:56 PM   #1
Default Major oil leak
I am a newbie to the world of bmw so I just brought a 2007 530i with 150k miles car drove fine and nice for a few days then while I was driving my steering wheel went real heavy and hard to turn so I pull over and pop the hood to see oil all over the left side of the engine bay the belt slip off with oil all over it any suggestions what could be leaking
Nate30504 is offline   Reply With Quote
Old 12-14-2017, 10:32 PM   #2
Power steering hose? Driver side or passenger side? Check power steering reservoir.
brow@garlic.com is offline   Reply With Quote
Old 12-15-2017, 04:08 AM   #3
Quote:
itís all over the driver side especially on the alternator the passenger side have little to none on that side
Old 12-15-2017, 08:36 AM   #4
Default Power steering
Quote:
Did you check the power steering reservoir? Heavy steering may mean broken power steering hose!
Old 12-15-2017, 08:55 AM   #5
itís steering heavy because the serpentine belt slip off due to the oil leak
Old 12-15-2017, 12:45 PM   #6
Razzy530's Avatar
oil filter housing gasket? check it. IT might be dripping all over your belts and creating slippage or worse
Razzy530 is offline   Reply With Quote
Old 12-15-2017, 01:26 PM   #7
Quote:
well be checking into that tomorrow also any other suggestions that can also be leaking that could make the belt slip off Iíll try to post up pictures tonight
Old 12-15-2017, 02:41 PM   #8
Here the picture of the leak
Old 12-16-2017, 01:57 PM   #9
That's a huge sudden leak
Listen to what others advice is
Check your power steering fluid level
If it's empty then you know it's a hose probably
Jack the car up and put it in safety stands
Take if the lover plastic and metal cover
And you will find the problem
E60Japanese is offline   Reply With Quote
Old 12-18-2017, 08:39 AM   #10
E60I's Avatar
I see a lot of oil residue build-up in the oil filter housing and green fluid (on air box). Your oil filter gasket and one of the coolant hoses could have been leaking for some time and got worse.
Clean up the mess with simple green cleaner (non bio-gradable to other plastic also) and start up the engine to look for obvious signs of leaks.
Cover up the alternator, get it "correctly" cleaned before it gets damaged. Don't get the alternator wet!!!!
E60I is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
N52 Oil Filter Housing LEAK - REPLACED Gasket and still leak?! DC5Series E39 Discussion 2 04-24-2014 05:20 PM
545i leak leak leak 545MMM E60 Discussion 1 05-15-2013 03:21 AM
2009 535i major oil leak, 52,xxx 535iduffer E60 Discussion 5 02-08-2013 12:06 PM
oil leak or diesel leak ????????? or any other fluid? peter530d E60 Discussion 0 01-31-2008 01:32 PM
Major oil leak from rear oil pan? brianstash E60 Discussion 6 01-27-2008 08:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content Copyright © 2012 by Internet Brands, Inc. We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
