Maintenance items at 40k/tranny fluid
My Ride: 2000 323i (Sport Wagon)
2007 530i
My wife's car is a 2007 530i and will hit 40k miles shortly (out of regular warranty/maintenance and into CPO). We've had the car for a few weeks now and likely plan to keep the car for several years. I want to get in and do any maintenance items which should be kept up with. I'm a 3-series owner and much more familiar with them and their weaknesses...
The first thing I want to hit are fluids: diff fluid, oil, coolant, brakes, and the big one: tranny fluid. Most of them should be pretty straightforward. I plan to put Redline in the diff. I guess I'll find out if the diff has a drain plug or not. As far as the tranny goes, I've read the long tranny fluid thread. I tried to negotiate a transmission fluid change when purchasing the car, and at first the dealer said yes, then the next day he said his mechanic didn't want to as it might void the warranty, and he just gave me cash off...
Has anyone experienced any issues changing the transmission fluid and the dealer claiming warranty problems? It makes me a little hesitant do the full change (ie the pan) as they'll know I changed it. However, with the CPO in place, I'd rather have the transmission decide to freak out on their dime. Regardless, I don't think at 40k miles there should be any danger of mysterious failure after a fluid change. Opinions?
Are there any other maintenance items or weak points I should keep an eye on? The 3-series is notorious for the cooling system failures (expansion tank/radiators/water pumps), but I haven't read the same here.
2007 530i
My Ride: 2004 545i Platinum Silver Metallic Gray Dakota Leather, Premium Pack, Premium Sound, Logic 7, Sport Pack, Navi, PDC, Sunshades, Cold Weather and HUD. 56k miles Feb. 2011
Check to make sure no sign of transmission leaking. If you always get a smooth stop and never felt any hard shift, then the transmission should be fine. No need to change the transmission fluid.
Lotus99
11-26-2015 11:07 AM
Maini
08-13-2015 03:40 PM
PelicanParts.com
08-13-2015 01:45 PM
PelicanParts.com
08-04-2015 01:34 PM
