Hello,
I have a 2009 BMW 528i. It currently has the stock 17" rims. I wanted to buy 19" staggered m6 style rims. However I'm not quite sure what the proper size and offset I should get. I don't want to have to put spacers or anything like that. Can some one please inform me as to what is the right size and offset I should buy? Some recommend 19x8.5 et.15 and 19x9.5 et.22? But I want a second opinion. The last thing I want is to order it and it not fit correctly... Do I also have to be concerned with hub bore size? Thanks |
Avant Garde no longer has the replica M6 wheels, it was replaced with the M355 wheels which are replicas of the F10 M5 and are similar looking. offsets will be direct fitment with ET18 in front and ET25 in rear with dimensions 19x9 and 19x10. let me know if you might be interested in a set as we are direct with them.
Originally Posted by NeRwEEzy
(Post 1470459)
Originally Posted by daniel0619
(Post 1470479)
Will that be a proper fit for the 2009 BMW 528i?
oem wheels plus on ebay has replica bimmer wheels with correct size, offset and hub centric. type in F10 or E60 M5 wheels and they should come up. They're warehouse is in Anaheim,ca GL
(Post 1470459)
Originally Posted by 04tl
(Post 1470747)
Would these offsets work on a 09 528 xi ??
(Post 1470757)
sorry those offsets will not work but there are offsets available for the XI models
(Post 1470447)
Hello,
I have a 2009 BMW 528i. It currently has the stock 17" rims. I wanted to buy 19" staggered m6 style rims. However I'm not quite sure what the proper size and offset I should get. I don't want to have to put spacers or anything like that. Can some one please inform me as to what is the right size and offset I should buy? Some recommend 19x8.5 et.15 and 19x9.5 et.22? But I want a second opinion. The last thing I want is to order it and it not fit correctly... Do I also have to be concerned with hub bore size? Thanks anything else you plan on doing to yours? |
| All times are GMT -8. The time now is 12:08 AM. |
