M5 166 and M6 166 wheels
My Ride: 2008 550i Space Gray and Black Dakota. Sports package with 19 style 172. First BMW and is AWESOME
Can someone tell me what the difference is between the M5 166 and the M6 166?
I currently run 172s and am looking into adding 15mm spacers in the rear and 5mm spacers in the front to make the wheels flush with the fenders ?? now thinking of changing my wheels to the 166. Which ones do I buy and do I still need spacers?
Thanks guys?..
Thanks guys?..
My Ride: 2004 545i TITANIUM GREY II on Black Dakota Lthr, Comfort Seats, Sports PKG, Premium PKG, Active/Dynamic Drive, NAV, Winter Package.
Buy the M6 Offset and no need for spacers. Or you do what I did buy the M5 offset with 12 mm spacers in the back as there is no need for the front. This way it is safer for no rubbing issues. If you search the forum you will find tons of data on this subject. Good Luck.
Thanks guys?..
Thanks guys?..
M5 166 offsets
F ET: 12
R ET: 28
M6 166 offsets
F ET: 12
R ET: 17
That 11 mm difference in the R ET's with the M6 offsets pushes the wheels closer/more flush to the fenders, as stated above, with M6 offsets, you most likely won't need spacers, with M5 offsets you can run spacers if you want them pushed further out as you will have room to work with (10mm or 12mm spacers)
F ET: 12
R ET: 28
M6 166 offsets
F ET: 12
R ET: 17
THANKS for the help.....so are you saying I might rub if I go with the M6 offset?
Not sure why I would with M6 but not with M5 and spacers....sorry new guy!
Also where does the tire rub?
if you run the recc'd tire sizes: Front 245/35-19" and Rear 275/30-19"
with m5 offsets no rubbing (including 12mm spacers)
with the M6 offsets, no rubbing as well unless you plan on lowering your e60.....in which it might rub...
no don't plan to lower my car at all....just want to go to the 166 and want the wheels/tires to be flush with the fenders.....can stnd how my 172s arent right now....
So would like to use the M6 with my original tires.....with no rubbing
