M Sport Conversion
My Ride: 2008 550i - Stock
So I have an 07 550i with sport package but not M sport package. I found used front and rear factory bumpers thinking it would be a direct bolt on which it was not. A few issues came up that I could use help with.
The rear bumper mounts a little different underneath. On the passenger side there was a splash panel that I head to remove or the bumper wouldn't mount. It sits under the passenger side under the trunk behind the rear wheel. Does anyone know what the M sport splash panel should look like and do you have a part #?
The other issue I ran into is that the front bumper also didn't just fall into place. It seems the inner fender liners are different for the M-sport. Does anyone have any info on those as well? I also had to modify the bumper foam support since it was a little too large.
Lastly I thought my sport windshield washer fluid covers and mechanism would transfer over but apparently it's a different size door and mechanism. Does anyone know a good place to get that or have the part #'s for it for BMW??
Thanks
Thanks
Engine: 3.0 B58; 3.0 M54
Looks like you started this conversion without doing any research. I'd suggest you going to realoem.com to find the answers you need.
Thanks for the tip. I looked into the parts quite a bit but didn't think there were different parts associated with the m sport besides the bumpers and side skirts. I'll check out the site you included. Thanks.
