low tire pressure warning
i got this light and don't know how to make it go away? one would say air up the tire, but the tire is in fact not deflated, so i guess it's just a false alarm that was accidentally triggered. thanks for the help.
did you actually check your tire pressure with a tire gauge?
doesn't take too much a difference in PSI to make the sensor go off, meaning you might not be able to tell by just looking at the tire that the pressure is low.
but the reset procedure is in your manual...just follow the instructions via iDrive to reset, but before you do, I suggest you check your tires with an actual tire gauge, that way you can measure the PSI's again if you get another tire pressure warning...you might have a slow leak or damaged tire/wheel...
There are plenty of threads addressing this issue, use the search button...
But its possible that the tire IS low. many times rft tires will not appear to be low, which is one of the reasons that the sensors are there (aside from the US requirements). Check it out and air it up. If its NOT low, then as mentioned int he last "help my tire is low on the screen" thread, air them all up, and reset the system in iDrive. You MUST drive to reset the system.
Lastly, perhaps your transmitters are running out of battery life and need replaced...
Tuffluck, are you running runflats? It is possible you got a nail or something in a tire and it hasnt begun to lose pressure... happened to me. Got a screw and when the screw flew out thats when the monitor notified me, yet the tire was still holding pressure.
The mention of the search request is becuase people are generally too lazy to find things out themselves, and we need to keep re-inventing the wheel, which gets lame.... Why have 1000 "My car says my tire is flat, WTF?" threads, when finding the one with the answers initially would have sufficed?
Of course, we could probably find 1000 articles on this subject too...
But we spoon feed those too technically challenged or lazy to figure things out themselves.
if you mean, suggest searching...IMO, it's because most likely this topic or something similar to this topic has been discussed, and rather than posting a new thread and waiting/hoping a member will chime in, the OP might be able to find the answer by him/herself much faster by using the search function.....
and I think there's a reason why using the search function is always suggested
for the most part, members here are pretty good about providing some insight/help along with suggesting to use the search function....unlike other forums/websites
Got it... i was just curious and thought that sometimes its just easier to answer the freakin question... anyway, good luck to the OP in finding the reason.
"Give a man a fish, feed him for a day. Teach a man to fish, feed him for a lifetime"
OP: good luck, keep us posted
That's why you've been instructed to use a pressure guage.
I know you're probably very very busy and asking a question here is easier than trying to find the answer in your owner's manual. That said, if you download the owner's manual for your year car [it's right in the info section of this forum!] you can search for answers on line in a New York minute and avoid the wrath of posters who will tell you to RTFM!
During the winter my TPMS light often comes on. Since the winter just started or is about to start and if you live in a cold climate this is a common occurrence. Just reset it and forget it .
