Low oil pressure, what do I do?
Old Nov 13, 2019 | 11:18 AM
Be_emer's Avatar
My Ride: 2007 bmw 550i
Default Low oil pressure, what do I do?
So I have an e60 550i and it has around 118000 miles on it. A week or two ago I got the classic low oil warning on my iDrive system. At first I brushed it off because it did not pop up after turning the car off then on again. Another week or so has passed and I just got it again. Being the second time this has popped up, I was very worried. However, when I got home, I turned the car off, then back on, and the earring did not pop up. I’ve been driving another car sense then just in case, but I’m confused as to what’s going on and I’m worried if I’m going to have to drop a lot of money on a new oil pump or something. I would love some experienced/ expert insight on my situation. Thank you.
Old Nov 13, 2019 | 08:13 PM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Are you talking about low oil pressure or low oil level? At any rate, check the oil level using the dipstick or i-drive and act accordingly. If low oil pressure, then have the oil pressure switch checked. Could (probably) just be a faulty or leaking oil pressure switch.
Old Nov 13, 2019 | 08:40 PM
Be_emer's Avatar
It’s low oil pressure, thank you for your advice though. I just checked the car again today. I turned it on, sat in it for around 5 mins and the low oil pressure warning did not come up.
Old Nov 14, 2019 | 05:31 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Low oil pressure should mean the oil is low, shouldn't it? Check your levels. It kees coming back for a reason.
Old Nov 14, 2019 | 05:47 AM
audiophool's Avatar
My Ride: 535xi
Low oil pressure isn't due to a low oil level. If your oil were low enough that the pump scavenged all the oil out of the pan before enough came back to suck up again, your oil pressure would drop, turning on the oil light/iDrive sensor, then come back.
Check the switch, or have a shop test it with an actual gauge. The switches can also fail and leak, which can simulate a short. It's at the front of the passenger's side head, under the vacuum pump (N62).
Old Nov 14, 2019 | 05:57 AM
Model Year: 2005
Engine: N62
Still, I would get the oil pressure sensor/switch checked.
Old Nov 18, 2019 | 06:21 AM
Deano's Avatar
I’ve replaced it twice in the past two years. Cheep fix but kinda hard you reach on an n62, but doable
elkk
Frequently Asked Questions
Apr 10, 2016 06:42 AM
Killa Instinct
Feb 28, 2013 03:26 PM
Ruf930
Lounge
17
Apr 28, 2011 10:29 AM
545iBMW
Lounge
May 25, 2010 09:18 AM
big_ipaq
Lounge
30
Oct 26, 2004 02:34 PM
