Low oil pressure warning
My Ride: 2008 550i sport package
Hey guys I'm new to the forum and I have a question, hopefully you guys will be more help then the dealership. I have an 08 550i, and a couple weeks ago I received the low oil pressure warning and it only happens when I brake. I also had issues with water frying my modules in the trunk and the dealer replaced that but they are also saying the low oil pressure warning is due to the many oil leaks I have like the alternator bracket and valve cover and also the valve stem seals but every time I get the warning I check the oil physically with the dip stick and on the I drive and both say it's ok amount. They want 4K to fix the leaks. Any opinions on if I should trust it will fix the problem? Any help appreciated thanks in advance.
My Ride: 550i
Model Year: 2010
the leaks have nothing to do with the low oil pressure. Replace the oil pressure switch (located under the vacuum pump) and see if the problem comes back.
My Ride: Sold: 545i, sport package, cold weather, 6MT
Engine: N62
+1 on replacing the switch. If you're mildly handy, it's not that hard.
Also, I would recommend getting the alternator bracket and other leaks done, but get an independent shop quote, not from a dealer.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
That is not 100% correct. If the leaks are bad enough and enough oil leaks you would get a low pressure message. If you are low on oil the engine cant produce enough pressure which triggers the low oil pressure message. First check your oil level if low fill and see if message goes away. If its not low then it would be the switch.
Model Year: 05 530i
Engine: 3.0 M54
The OP stated that he/she checked the oil level and it was OK, although it wasn't quite clear exactly how the OP checked the level. The fact that the low pressure message comes on only when applying the brakes (low engine RPM), does indicate either a low oil level OR a leak right at the pressure switch OR faulty switch.
Yes I read what the OP posted but I was simply replying to the quote in my post because the post was incorrect (enough oil leaks out then you will have a low oil level). Low oil level will give you low pressure. Oil level has a lot to do with pressure. I also went on to say if the oil level is not low then it would be the switch.
