low oil
Old Oct 31, 2011 | 04:19 PM
white777's Avatar
Having to add engine oil to my 06 e61 every 2 months or less is anyonelse having this problem or have any advise or solution to my issue.
Old Nov 1, 2011 | 01:11 AM
seanjordan's Avatar
My Ride: 05 BMW 530I
You may have a valve cover leak. Do you smell oil around the engine or see what may look like steam when you park or sit at a stop sign. If you are frequently putting oil in the car as much as you say their is definitely a leak and definitely signs of it.
Old Nov 1, 2011 | 01:38 AM
KAF's Avatar
KAF
Model Year: 2015
Engine: N55
I agree, either an oil leak or oil burning issue
Old Nov 1, 2011 | 03:46 AM
pcy's Avatar
pcy
On average, how many miles do you drive in 2 months?
Remove the plastic shields under the engine area and look with a flash light. If you don't see any visible leaks, then we'll have to assume that the engine is 'consuming' that oil. If you do see oil leaks, trace oil to the source of the leak. If you can't tell where it's leaking from, clean the entire area with engine degreaser or brake parts cleaner and check it after few days.
Old Nov 1, 2011 | 10:14 AM
white777's Avatar
checked and don't see any sign of oil leak .also there is no smoking i drive about 300 mi a month .
Old Nov 1, 2011 | 01:29 PM
seanjordan's Avatar
I don't know what the miles have to do with it but I change my oil every 10000 to 12000 and I have only had that issue once at 80000 miles and it ended up being a valve cover gasket. My vehicle has 94000 miles and it has not ever burned oil like that and I am a hard driver.
Old Nov 1, 2011 | 05:03 PM
pcy's Avatar
pcy
At 300 miles a month, having to add 1 qt of oil for every 2 months (600 miles) is a LOT. If you don't see any visible leaks under/around the engine. Then, definitely, engine must be consuming... If I were you, have an independent mechanic diagnose internal oil leak.
Old Nov 1, 2011 | 11:32 PM
seanjordan's Avatar
Personally, I think having to add any oil between oil changes is too much. You should not be adding oil to the vehicle between cycles at least that is not the norm for me. If I have to add oil to any car between cycles then there is an issue and if it cant be fixed then I would get rid of it.
Old Nov 2, 2011 | 05:30 AM
wi8123's Avatar
Alot of 5er owners complain of this same problem and most if them dont have leaks either hmmmmmm ....My car even drinks oil more than normal....
Old Nov 2, 2011 | 03:16 PM
white777's Avatar
what do you mean by internal oil leak
