Lost One Quart of Oil
Originally Posted by juris335' post='871644' date='May 7 2009, 09:28 PM
New 6,000 miles ago my 535xi now tells me I am one quart of oil low. Could I be using 1 quart of oil every 6,000 miles? I can find no leaks. What is par for this engine? Should I be losing sleep over this?
In fact, my '07 has a quart of BMW Synthetic Oil in the trunk - been there since new and I've not needed to top off between services (now at ~29K miles).
My Ride: 2005 BMW 530d M-Sport TouringExterior: Titansilber Metallic, M5 mirrors, ACS rear roof spoiler, BMW Carbon Fiber rear diffuser, Adaptive Xenon headlights, AngeliBright v.3 Angel Eyes, F1 Autohaus Euphoria 6000K LED license plate lightsInterior: Black
Originally Posted by juris335' post='872114' date='May 8 2009, 03:56 PM
I've had 9 BMW and am not aware of ever needing to add 1 quart of oil. My 145,000 mile 740i does not use one quart of oil. This is a big surprise.
My Ride: 2008 535i 6MT
BMW and many manufacturers formally define excessive oil consumption as more than 1 litre in 1000 miles. The OP is consuming 6X LESS as are most BMW drivers with an inline 6. It's normal for the BMW inline 6 to consume oil.
My 2002 520i (2.2l I6) used about 1 liter for every 2000km. I owned since new, followed the break-in procedure to the letter, and had it serviced as required.
The first time that I mentioned the oil consumption issue to my service department manager, he laughed and then gave me a free liter of oil. No worries.
That said, after 6000km in my 530d, I have not noticed any oil consumption. It will be time for the annual oil change in November, so I will see then how it has gone.
My Ride: BMW 535xi
![Unhappy](https://5series.net/forums/images/icons/icon9.gif)
Originally Posted by Patrick E61' post='872156' date='May 8 2009, 08:37 AM
How often do you change your oil?
I just went to the dealer who told me it is normal to use 1 quart every 5-6K miles. He said the X-5s average about 2 quarts between oil changes. I can't imagine why I am not smoking like a chimney... He added the 5-30 quart at no charge.
None of my BMWs has consumed oil between changes, at least not enough to warrant topping off. That said, I have seen various references to oil consumption being normal on the 535 on this forum. The N54 is just a different animal.
My Ride: BMW 535xi
Originally Posted by slickE60' post='872767' date='May 8 2009, 06:01 PM
Did your engine burn this oil or did it end up in your coolant as was the case with my car when my head cracked? ![Embarrassment](https://5series.net/forums/images/smilies/imported/ohmy.gif)
With my previous 9 BMWs they lost a negligible amount of oil. With the 5er it seems it is a Badge of Honor to lose oil...
Originally Posted by juris335' post='872905' date='May 8 2009, 07:48 PM
Rick - I don't know the cause of my loss of 1 quart as I have not ever had the car serviced. I know I am a doubting Thomas but it is so difficult to accept that it is "normal" to drop 1 quart every 5-6K miles.
Originally Posted by GregBrand' post='873483' date='May 9 2009, 11:05 AM
How can I get a Blackstone analysis of my oil? Would the results be misleading since it is my "brerakin oil"? Wouldn't a Blackstone analysis be more instructive if I ran it on the oil after the breakin oil is removed? Thanks.
![Nono](https://5series.net/forums/images/smilies/imported/nono.gif)
An oil analysis can be done at any time - even a new engine can suffer a failure in its seals, bearings, gaskets, etc.
