Looking to buy a 2004 545i. What should I be looking for?
My Ride: 98 318ti
Hey guys,
So a cars popped up on Kijiji and I've taken interest, Its a 2004 545i with a 6speed. The car is fully loaded and my only concern at the moment is high kilometers(208k). So my question is what should I be looking for? Is there any problems I should expect with an early model e60? The owner is asking 8500 and I need to know what to look for to help me haggle.![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
Thanks,
David
Thanks,
David
My Ride: 2005 545
Hey guys,
Thanks,
David
Thanks,
David
Second .. Have all the recalls been addressed . They should have if he takes good care of it.
Third ..... Ask if the coolant pipe has been replaced .
Fourth. .. Ask if the alternator bracket gasket has been done. These are the two big ones and most important to know a out.
Check for leaks on the valve covers a nd front timming covers . Those leaks are not as critical as the other two but can give u alittle leverage if they are leaking.
Ask if the transmiission has had any software updates.
Ask if the modules inthe trunk have been relocted to the side panels. Water can get in there from clogged sunroof drains and also make sure that all six drains flow water out.
Hope this info helps u on your purchase. A well maintained 545 is an awesome machine. Will for sure meet ur driving pleasures.. Good luck
My Ride: 545i
First ask the owner for his service history. Specifically fluids. How often has he changed the trany ,oil , coolant , hydraulic . brake , and rear end gear oil. This will give u an idea how well he maintained the car a nd also what needs to be done
Good Luck with your search.
My Ride: 2005 545
I agree with the above. I would add the suspension to the list and cooling components such as the expansion tank, radiator, hoses, thermostat, and water pump. I had 2 big coolant leaks. One was vent hoses form the heads to the tank, and the other was the tank. The plastic was so brittle. I replaced the parts before it was catastrophic and left me stranded. Front arms/ball-joints do go out especially at higher mileage. I bought mine well maintained (trans, coolant pipe, timing cover seals, valve cover gaskets ect. all done) and had front bushings go in the first month. I replaced everything in the front end...tie rods, wishbones, tension arms, and sway bar end links. Other than that the secondary air system can plague these cars. I cleaned the head passages out (with the engine in) and it was a good 6hrs and a pain in the ass using an air compressor and a brush. The last owner replaced the pump a year back. My car is now running flawless for the last 4k miles. Rides like new.
My Ride: 545i
No pics. I can give some tips. (sorry to thread jack but OP this is something you may face on day)
After the intake manifold is off remove both secondary air check valves on the rear of the heads. I then took a can of carb cleaner and filled the passenger side first. My passenger side was clear and the fluid was able to drain right into the exhaust through the head passage(s) very easily. The driver's was clogged (and I was getting the low flow code on this side). I let it sit maybe 10 minutes. It seeped down a tad. I took 100psi of air and blasted the driver side passages. I tried to use a brush but it was hard to fish. The main thing is you need to find a way to seal your air line against the tube that goes into the head. I used a rubber stopper and electrical tape on the end of my air hose nozzle. I held it against the valve mount as tight as I could and after about 10-20 100psi bursts air flowed freely. (used about 2-3 cans of carb cleaner during this time also). When that was done I reassembled everything. Car smoked quite a bit. (I waited a while to run it so that some of the cleaner could dry up. I would hate to hydrolock an engine). After this I cleared the CEL and it has not come back.
Here is a DIY on removing the intake manifold. It is for a 6er but same process.
I am not responsible for anyone damaging their car. This procedure happened to work for me.
http://www.bimmerfest.com/forums/att...3&d=1299748784
This will help you understand what I was cleaning.
A warranty ASAP!
![Online2long](https://5series.net/forums/images/smilies/imported/online2long.gif)
Hey guys,
Thanks,
David
Thanks,
David
