Logic 7 not outputting sound from AM, inbuilt cd and dvd, and satellite radio
Old Apr 15, 2024 | 12:39 AM
quardigras's Avatar
My Ride: 2005 e60 545i
Model Year: 2005
Engine: 4.4L V8 N62b44
Default Logic 7 not outputting sound from AM, inbuilt cd and dvd, and satellite radio
Hey first time poster here
My 05 e60 with logic 7 professional ccc isn’t outputting any audio from the inbuilt cd drive, the am radio, or the wireless radio. Also get no audio from the check control messages, PDC, or the voice control. But the fm radio, handsfree, and the cd changer all output audio to the amp.
Could this be a coding issue? I’ve looked everywhere and i've only found people with absolutely no audio whatsoever, with the solution to be to replace the amp. However my amp clearly works perfect.
Any suggestions? I have the materials to code myself.
Old Apr 15, 2024 | 07:58 AM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
It would be helpful to understand the history of your car and the CCC and Logic 7. Did you just get the car and it isn't work? Did you not have Logic 7 and install it from a junkyard? Did you try to code something and now it isn't working? How do you know "[they] all output audio"?
Old Apr 15, 2024 | 11:08 AM
quardigras's Avatar
Model Year: 2005
Bought in 2014 from a private seller, then never drove it until this September. Factory came with logic 7, and every speaker seems to output audio. I can play music from the cd changer in the glovebox, but im unsure if the inbuilt cd player in the CCC works at all. It reads the discs and says they’re playing, just not outputting any audio. Same thing with the dvd drive for the Nav.
Would there be a way to recode the CCC to my car if the previous owner ended up coding anything or would that be too risky?
Old Apr 15, 2024 | 11:25 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
You can recode the car if you have the necessary software to do it without any issues. I would check in INPA to see if anything was replaced and not programmed/coded correctly before trying to code it.
Old Apr 15, 2024 | 12:34 PM
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
Am I to understand that you purchased the car in 2014 and let it sit for 9 YEARS?
Old Apr 15, 2024 | 11:12 PM
quardigras's Avatar
Model Year: 2005
Well, my dad purchased it for himself, then got a truck which turned into his daily. Drove the car maybe once every 2 years, until I got my license and put 7k miles on it so far. Unfortunately I have that good old n62 engine taking up all my budget. Currently working on fixing it, but this car is gonna be my baby.
I found these instructions on a youtube video, just wondering if this looks correct? Should I check over the V/O about the options in my car before continuing? I remember finding a document somewhere about the available V/O codes for the E60 and could probably find it again.
Old Apr 16, 2024 | 12:52 AM
I would go to INPA first before trying to factory code anything. Post the UIF and error page in INPA
Old Apr 16, 2024 | 10:34 PM
quardigras's Avatar
Model Year: 2005
Unsure what any of this means but here you go.
Fault codes here:
1/3
2/3
3/3
Old Apr 17, 2024 | 03:46 AM
Looks like you have a failure somewhere. Either the CCC has an internal failure or your MULF is bad. The MOST network is having an issue and that's what it's pointing to.
Old Apr 17, 2024 | 04:02 PM
quardigras's Avatar
Model Year: 2005
Do you think I could fix this on my own? Would that stop the audio just from specific modules to stop working?.
