logic 7
hi all
i am in the middle to upgrade to logic7
i run into a bit of the problem ,,on the rear doors i found this wire loom connector ( have inside 3 conectors)
witch pins of witch connectors are for the +/- of the speakers signal?
also..were do i take the most for this? i circle in red
anyone have a pin out schematic ?i circle in yellow
thx u
thx u
In that wire loom connector it's not important witch is the + and witch the -. You must add new wires because there is no wire from amplifier to each door, and neither inside the rear door.
For MOST signal you will find a MOST distributor under the trunk carpet, near the left strut.
i know i dont have the signal thru the loom but must be a pin(s) dedicated to the speakers so i can feed the signal
i have tcu neear the hi-fi amp so i have bridge the fo signal from tcu to logic7
please ;pm with your skype id so u can talk
thx u
thx u
bestofthebest
01-05-2016 07:47 PM
viper1213
08-19-2015 09:56 AM
