Location of Mass Air Flow Sensor
Old 06-06-2014, 12:27 PM
ranman24's Avatar
My Ride: e60 535i Sport
There are two sensors. The one on TOP back of the engine on the intake manifold (as pictured from the previous post) and one just prior to the throttle body on the INTAKE TUBE coming from the TURBO's intercooler. This MAP is on the back side of the tube.
FYI - for those folks who post without answering a question, which causes all of to scroll through none-sense. The intake comes into the intake box that wraps around the back of the engine, then down to the passenger side to route through the turbos and intercooler, then back up and under the box to the throttle body. The air takes an entire lap around the engine before digested.
Attached Thumbnails Location of Mass Air Flow Sensor-screen-shot-2014-06-06-4.20.19-pm.jpg
Bassbimmer (01-10-2020)
Old 12-10-2016, 03:31 PM
pgreenx's Avatar
My Ride: 2008 535 XI
This helped a lot - I found it by accident who I took the engine cover off to change spark plugs. Bently seems to call it "intake manifold charge air pressure sensor".
Per Bentley There appears also to be a "charge air duct pressure sensor". Can anyone tell if this is similar and do I clean them both the same way?
THanks
Stranger12
04-05-2015 10:42 AM
rorschach76
03-19-2015 08:59 AM
sh71jj
08-02-2004 07:56 AM
535D Sport
07-18-2004 01:35 AM
08-12-2003 11:41 AM
Quick Reply: Location of Mass Air Flow Sensor
