LM2 Fog Light problems
My Ride: BMW E60, F01 750i, E61 530xd
Hey,
I recently retrofitted my LM2 module. Everything works great, but the front fog lights are acting weird. When ignition is on I can turn on the front fog lights but can't turn them off. And when engine is on and I turn front fog lights on, they stay on for couple seconds and after that the rear fog lights turn on and front ones turn off. When I click again front fog lights it turns them on again for couple seconds and then turns off all the fog lights.
Has anyone else experienced this, is this just some coding problem or is the LM2 just faulty?
My Ride: 2006 530xi (One black & one grey) 2010 X5 35d 1974 BMW 3.0CS 2008 535i, 2009 335d, 2011 X5 35d, 2008 335i FBO
I would go back into the module and code it for regular operation, no wake up features with unlock or anything like that . . . Then try them to see if your issues go away. Also check your pathway light settings in the idrive. Pulling back on left stalk should cause the headlights to turn on, giving you security lighting while you enter building etc . . ., scan the module for codes and post findings.
carid
Jan 6, 2015 02:01 AM
