A Little Play in a Pulley
1 Attachment(s)
Hello fellow members,
I have a couple questions that I hope someone here can answer. There is a little play in the main pulley at the front of the motor in my '06 550i. It has 2 belts attached. (It's the large pulley in the center of the attached photo.) What is that pulley? How serious is it that it has a little play? Any idea how much it would cost to fix it, if necessary? Car runs great. Thanks for your help. Psam550 |
Are you talking about your water pump (top/right)? Depending on if it has been replaced before how much it would cost. Have you tried tightening the 4 nuts on it? How many miles does your car have?
(Post 1571416)
Psam550. |
The a/c compressor at the bottom?
1 Attachment(s)
(Post 1571423)
The big pulley just below it. See photo, below. Is it easy to remove the plastic air intake module above it, so I can reach in and tighten the pulley? See the other photo, attached, below. Thanks. Psam550. |
1 Attachment(s)
This plastic air intake.
Crankshaft pulley. It has two belt on it
Yes it is fairly easy. Look at the beginning of this video and it will show you how.
(Post 1571429)
Yes it is fairly easy. Look at the beginning of this video and it will show you how. Video
If tightening the pulley doesn't work (which I don't think it will), your pulley may be going bad. The rubber insulating both metal sections of the pulley is most likely disintegrating, causing the wobbling.
