LHELP! Cracking & Poping Noise Front Right when Turning
My Ride: 2006 550i Black Saphire/Black Dakota Leather- Loaded- M5 Appearance Package, Sport Package, Pro logic 7 Premium Sound, Navigation, Cold Weather Package, Comfort Package, Heads-up Display, park Distance Control, Bluetooth, Active Steering, Electric Rear Sunshade, Rear Folding Seats, Front/Rear Heated Seats, Xenon lights, Satelite Radio- Extended Maintenance, CPO (Considering Tire/Wheel Insurance)
Any time I turn left when moving (car leans right) there is loud clicking and banging coming from front suspension?? or something?
Had a mechanic put on lift quickly and there is nothing obvious or broken showing.
Advice please?? Has anyone had this?
Does it make the same noise when turning to the right?
In addition to the above comment, this also sounds like a classic bad wheel bearing symptom. You can do a quick check yourself by jacking up the right side and placing your hands at 12 and 6 on the wheel. Push in and out, alternating between 12 and 6, if there is any play, then you might have a bad wheel bearing. Get it checked out by a mechanic, if it fails while driving, you will be very unhappy.
TexaZ3
05-06-2015 09:54 AM
