Left tail light dimmer than other... Normal?
My Ride: 2008 550i M-Sport: RPi GT Exhaust, RPi Ram-Air, GP Thunder angel eyes and fog lamps, LED license plate lamps, Full LED interior
I've noticed one of the left tail lights is dimmer than the one on the right. I've swapped bulbs and such, but it's still the same. Is this normal?
When removing the bulb housing and looking at them, this particular bulb on both sides is rather dim, with the right side being only slightly brighter.
And I've tried putting the stock license plate bulbs back in, thinking that maybe the LEDs were drawing more power or something, but the result was the same.
See picture.
See picture.
Are your fog lights on? I believe that BMW's have one bright tail light when the fogs are on, helps with visibility from the rear when in foggy conditions.
when that happened on my other bmw, it was due to one socket was worn/bad. i was a cheapy and ended up repairing it myself (i cleaned off the carbon and added a new tong) but i work in Engineering and had the tools available so was no biggy.
Okay, thanks guys. It's still under warranty / maintenance so I'll just have them look at it the next time it needs maintenance.
My Ride: 2006 BMW 550i
i've seen this on a friend's car where his one rear turn signal was dimmer than the other. changing bulbs didnt fix. if i remember right, the inner wiring connector on the light was creating extra resistance due to slight corrosion or something. ended up just sliding the connector on and off several times and it fixed the problem.
socale39
09-05-2023 08:30 AM
rizwan1377
04-05-2015 05:22 PM
andymax
03-13-2015 10:51 AM
