left datetime running lights faulty
My Ride: bmw e60 msport
Model Year: E60
Engine: 2.5
I put in after market led's to my 07 e60 now iv two faults on idrive when I plug in carly and chose coding and lma and look for the day time running light theirs a few options so I just chose daytime running lights off and the right fault is gone off idrive but left is still their any ideas
With LED lights, if they are not fitted with a resistor they will briefly flash on startup and the error message will show up on idrive. With Carly, there are 2 options that can be set for those circuits you use LEDs on. This will code out voltage monitor and bulb out checks, I believe they are called. Code them out, no problem, the idrive moniter just won't tell you if the bulb burns out.
