Learn function for sunroof?
Hello folks,
Listen i want to ask you if there is a learn function for the antitrap of the sunroof. The thing is i recently upgraded my cip to latest version (i think 31 or so). Anyway it was big impact especially on layout and colors (i now have the grey disply not the brown one). After the upgrade everything was ok with a couple of notes on the bad side:
-antitrap function for the windows got alot more active, refusing to close the window. Had to close them bit by bit.
-when i opened the sunroof and i closed it when i arrived home i noticed that it wouldn't close. It went to the end as it should move but exactly when closing and lifting the back end of the sunroof into position it behaved like the antitrap and reversed the closing procedure, opening the sunroof again. Tried it like the windows, bit by bit but it didn't work. Tried it many many times but no chance to close it. Then i gave up and went to manual closing with the allen key.
So now i'm asking is there a way to learn the close and open procedure of the sunroof?
Can anybody help pls?
Thanks!
Thanks!
Originally Posted by Rudy' post='625495' date='Jul 16 2008, 06:11 PM
Hey Rudy,
That didn't work. I mean i tried to normalize, initialize, learn the characteristic curve...all that seemed to be related to keeping the lift button pressed for more than 15 seconds. I tried it and nothing happened, just that the sunroof lifted as usual.
Anything else that i might try before taking it to the dealer?
Vman33
03-14-2022 04:43 AM
