Leaks
My Ride: 2013 M5 - Sakhir Orange / Black Leather.
I've noticed a small bit of oil staining around the oil filler cap and also fluid around the power steering fluid reservoir. I've cleaned both areas up and replaced the caps tightly, but after a few days it occurs again. Clearly the caps are leaking. I will ask the dealer to replace both caps. Anyone else have this problem?
Power steering reservoir cap has a hole in it to relieve excess fluid. Its designed this way. Maybe just check the level of the fluid - I'm suspecting it might be over-filled. Not sure about the oil.
My Ride: 530i Built Nov 06
Silver Grey with Black Leather
Steptronic Automatic Tranmission
Premium Package
Navigation System
Sirius Satellite
Red Reflectors :-)
I am not sure about oil filler cap, but my ps fluid cap had the same oil stain problem. There is a o-ring seal you can just buy from the dealer and replace it. I did and it resolved my problem.
Originally Posted by JDN' post='303330' date='Jun 26 2006, 05:54 PM
Cleaning the power steering cap leak will have to become a habit if it bothers you.
Usually after the service one can find some spills,
but after cleaning the engine compartment
there should not be any leaks!
