Leaking timing covers
My Ride: 2004 545i Sport
2004 545i with 103,000 miles
Recently experienced small drips of oil under my left front side of engine. Could not find the source from above or with a flashlight. Took it to my mechanic and he diagnosed it as a leaky oil pain and some gasket on the alternator. After 5 or so hours of labor later I received my car back.
Days later notice an oil leak in the same spot but seems worse. Took it back and he now diagnosed at a leak in e timing cover gasket? A 34 hour job. Somewhere around 5000+ to fix.
Anyone heard of this as a common problem? Should I jus sell my car and cut my losses or get a second opinion. By the way, there wasn't any change in performance or rough idling or anything. Car runs great.
My mileage just around 93k and I found oil leaking also but it was my valve cover gasket. I had them replaced and no more oil leak. Good luck with your repair but its about that time for the valve cover gasket to be replaced if you have not done the replacement yet.
look at valve cover gaskets first...they usually leak right at the corner, and will make it look like there is a gasket behind the alternator leaking. There also may be oil "dripping" from the control arms. Mine are leaking with 71k miles.
*If* the timing covers are leaking, and its the two upper ones, then it is an easy fix. The lower one is a bit more time consuming. It seems like he is changing his diagnosis quite a bit. I would get a second opinion, or get a flashlight and trace the oil as high as it will go. The lower oil pan is more prone to leak (steel), but not the aluminum one.
