LCI headlights interchangeable with previous?
Old Jul 23, 2009 | 12:11 AM
Westfield's Avatar
Are the 07+ LCI xenon headlights completely interchangeable with the pre-LCI xenon headlights? Can I carry over the xenon related stuff like bulb, ballast and ignitor?
thanks in advance!
Old Jul 23, 2009 | 12:40 AM
Dav530d's Avatar
If you have the later model with D1S bulbs then yes. Not too sure about the adaptive module.
Old Jul 23, 2009 | 04:03 AM
Westfield's Avatar
hi
thanks - what is the "adaptive" module? is that the motor that makes it go up and down? that's contained inside, right? My car is a 2004, so probably I don't have the D1S bulbs...
Old Jul 23, 2009 | 04:21 AM
Howitzer's Avatar
I believe you must have Xenon pre-LCI fixtures in order to get the LCI version and use them without errors. I also believe, don't quote me, that you need an adapter, (similar to Bruce cables), like you do in the rear for the LCI tails.
Old Jul 23, 2009 | 01:26 PM
Westfield's Avatar
Ok, thanks
I'll just stick with getting some identical then.
jcolley
Dec 8, 2021 05:00 AM
ricki_
12
Feb 8, 2020 09:50 PM
Kasmo
May 7, 2019 03:30 AM
milhouse4u
Apr 22, 2015 04:43 PM
rizwan1377
Apr 5, 2015 05:22 PM
