Kind of Popping sound on 545i suspension. Need your help
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
I recently replaced front sock absorbers, shock mounts with Same OEM except the pads and springs. sometimes I had that sound before going over the bumps like the popping sound and thought it was the absorbers or mounts but after replacing them the same sound from passenger side. Thought this was from control arms. Tie rods, or links which I replace as well including inner tie rods. But the sound still there. I have a passenger side engine mount old cause was not able to replace it without the lift but driver side mount is new. Does anyone have same problem? Do you think it is shock mount or pad. I can't figure out whor else it might be. ![Bashwall](https://5series.net/forums/images/smilies/imported/bashwall.gif)
Model Year: 2005
Fixed it as the strut top bolt was not torgued completely. After retorgue no more popping. Anyone knows tow to use a torgue wrench for this bolt as it spins and can not torgue it with torgue wrench to the proper specs?
srogers535x
14
04-26-2015 09:39 AM
