Key Remote
Old 08-16-2005, 11:32 AM
PKandCK's Avatar
My Ride: 545i Orient Blue, Auburn Int. Sport Pkg, Premium Pkg, Satellite Radio, Logic 7 , Nav... European Delivery 3/21/05 Redelivery 6/1/05.
When I first picked up my car the remote on the key would lock/unlock the car from quite some distance. The car is now 5 months old and I have to literally hold the key right at the drivers door within 12" for it to work. I tried using the spare key and had the same result. Any ideas as to why this is happening? It seems to be getting weaker every day. I know the key also holds memory for a variety of things... are they going away also? :'(
Old 08-16-2005, 11:50 AM
UUronL's Avatar
My Ride: 2006 530i Sport Silver Gray - Black Leather - Anthracite Maple Manual Transmission Premium Audio Cold Weather Package Rear sunshade Sirius Radio Autobahnd Roadblock (3M) film kit
Originally Posted by PKandCK' date='Aug 16 2005, 02:32 PM
When I first picked up my car the remote on the key would lock/unlock the car from quite some distance.? The car is now 5 months old and I have to literally hold the key right at the drivers door within 12" for it to work.? I tried using the spare key and had the same result.? Any ideas as to why this is happening?? It seems to be getting weaker every day.? I know the key also holds memory for a variety of things... are they going away also?? :'(
[snapback]159945[/snapback]
Well, the spare might just be low on juice - the keys need to be cycled so that they don't die (internal batteries). That doesn't account for the bad performance with your "regular" use key though. I'd mention it next time it's in for a service.
Old 08-16-2005, 12:07 PM
mixterk's Avatar
My Ride: Current - 330 Sport Topaz Blue, Grey Leather, HK HIFI...lost interest!! Waiting for - 535d Sport, Silver Grey, Foldy Mirrors, 172 19",Logic7,Pro Radio,Through load,Heated Front Seats,High Gloss shadowline,Black Maple,Headlight wash,Sun Protection Glass.
Try this...next time you are out of range, hold the key against your head and try again. Bet you it works!!!!
Old 08-16-2005, 12:11 PM
Banned
stream's Avatar
Originally Posted by mixterk' date='Aug 16 2005, 01:07 PM
Try this...next time you are out of range, hold the key against your head and try again.? Bet you it works!!!!?
[snapback]159955[/snapback]
It actually does work. The remote on Carreras has horrible range, and one day I experimented and found it doubled the range when you did that (even doubled range was less than on my 545i!).
Old 08-16-2005, 12:14 PM
mixterk's Avatar
Now thats using your head!!!
Old 08-16-2005, 12:17 PM
Hobi's Avatar
My Ride: 2005 MY 545i Sport Saloon. 2006 MY Alpina B3S Convertible. 2006 MY Brabus Smart 42 Cabrio. 2006 MY AM DB9 Coupe.
If it's any help... my car has had this problem and BMW GB initially changed the antenna amplifier located in the rear headlining and also the fin aerial. Same problem after this warranty work...
Car has been in whilst I've been away and they put in a new rear windscreen last Friday. Apparently, the problem is now solved. Look like it was defective pickup elements in the rear windscreen itself.
Will test it out later this week.
I thought I was the only one on this forum with this problem...
Old 08-16-2005, 01:22 PM
JARRETT's Avatar
Arrow
Your key shouldnt be doing that unless u dont drive the car a lot, because every time your driving the car the battery in the remote is suppose to be getting charged, have your dealer look at it.
Old 08-16-2005, 03:48 PM
MEX
MEX's Avatar
i always use it next to my chin, my gf always laughs at me. She thinks its funny that it actually works
Old 08-16-2005, 07:40 PM
Dantheman's Avatar
Yah! rumors has it that it fries your brain!
Old 08-16-2005, 08:07 PM
PKandCK's Avatar
Am I being naive or gullible? How does holding it near you head work? Both keys are used about equally... and both have the extremely low range. Perhaps I should ask the dealer... This will be my first problem...
Quick Reply: Key Remote
