Just dropped $1046 at the dealer....and a question
My Ride: 2008 550i w/M-Tech, Sport and Cold Weather Pkg
I have attached the invoice for an oil change, 2 new thrust rods and a complete update to all modules. I told them money was tight so they discounted $263.53 off the bill which I assume was just pure extra profit. Anyways car feels great. I brought it in because I had a lurching when down shifting into first just before stopping. Thought it was an update to the trans control module but they said after almost 70k miles the thrust rod bushings were toast which I suspected anyways due to intermittent steering wobble.
Anyways they also mentioned my vacuum pump was leaking oil there at the front of my 4.8 V8. I read here that BMW makes a seal replacement kit so I asked their parts dept and all he showed was one O-ring which they stock (part 11-66-7-509-080 for $13.89). Does this sound like what I have heard referred to? Or there an actual kit with several seals?
Also heard the is an oil pressure switch or something else there that should be replaced as well....?
The kit is just the o-ring. Mine also leaked but, all I did was apply a gasket sealer on the O-ring and re-installed the pump. Some one actually did a great DIY on this.
If you're planning on removing the pump I'd recommend you buy the oil pressure switch and replace it. This switch is notorious for leaking in our engines as mine did. It is a pain to replace with the vacuum pump still on but, it can be done. It is located just under the vacuum pump but further back. I somehow managed to install it with the pump still on. BTW you're gonna need a big ass socket - 27 mm I believe.
Thanks e6t.lab.rat! I just bought the seal and the switch. My only question is the YouTube video I saw mentioned having to manually turn the crank with a pry rod to get the vacuum pump seated correctly when reinstalling. Is it really that big of a deal or can I just eye the pump and the gate upon removal and try to line up again on reinstall?
just turn the pump shaft by hand and try installing. if it doesnt go in, turn it a bit more and try again.
My Ride: 09 550i 6sp M-Tech. 18mm spacers rear, 8mm front. Dinan intake and Stage 2 tune. Tinted tails, M5 OEM lip spoiler.
08 Z4 3.0si Black on Black with Beige top. Removable hardtop. (Hers)
06 Volvo S60R Heavily Modded!! Gone and missed.
ditka550
Depends what is leaking. Is it the seal in the vacuum pump itself or the seal between VP and the timing cover. And if it's the seal in the vacuum pump, you might want to check a local gasket&seal shop to source a matching one.
and what are thrust rod bushings?
Consider replacing the oil pressure sensor. And the socket is quite specific: you need a deep one, but not too deep (as it will be hard to fit it in a tight spot there).
The o-ring in the pump head leaks too but there is only one place that sells this ring and it is not the dealer. I forgot the site. If you cannot find this o-ring I would clean and dry the o-ring then use some Hondabond 4
sorry here it is
http://www.bmpdesign.com/product-exe...earch_model/15
sorry here it is
Thrust arms are the control arms, dealer said they have 3 different names. They said the bushings are sealed and have hydraulic fluid in them and over time they wear down or the fluid leaks out allowing the arm to travel more than it should. The intermittent steering wheel shaking is gone now and overall the car feels WAY tighter and the steering more precise.
