Jammed White Bars on Tachometer?
My Ride: G30 M550i
Model Year: 2018
Originally Posted by AC_S5' post='436691' date='Jun 17 2007, 02:38 PM
He say it run from 4600 to 5000, I figure he's trying to say is moving from.
If not then get it check by the dealer.
I don't know of any change in the newer cars -- it wouldn't make too much sense -- I'm thinking the OP's car is operating normally. There are always a few white bars visible as a warning that you're approaching red line...
My Ride: In a place where the Mercedes density is the highest in the world (no. of MB per square kilometer) I choose a Bimmer, why? because of one thing "The Ultimate Driving Experience"
My Ride:
523i Steptronic, Silver Grey Exterior, Black Interior with Black Dakota Leather and Maple Wood Trim. Chrome Grill, Style 123 rim, Airbags everywhere, PDC, Rain sensor, Auto lights, Moveable front armrest, Advance Climate Control, Glass Sunroof, Auto dimming interior and exterior mirror with foldable functions, Extended Lights package, 6 CD changer in glove box, Power seats with memory, Power adjustable steering wheel, Power rear sunblinds.
Add ons: 123 wheels, chrome grill, K&N Hi flow filter, Eibach Pro Kit, e60.net decal and 24,000km
Past rides:
2001 Nissan Xterra SE
1999 E39 523i
1999 E46 323i
1996 Acura Integra LS
Originally Posted by Rudy' post='436807' date='Jun 18 2007, 10:36 AM
With only a 400 rpm spread, it sounds to me like he's not talking about the movement, he's talking about the lower and upper limits of the bars.
But with my car on a warm day like now, when I start up it have 5 white bars but after a while 3 is left so it seems like there's no movement but it actually does have movement.
Maybe the poster could try the trick to test to see if everything in the dash is functioning correctly by having the key without starting the car in position 2, then press the trip button until some German comes up. Now I am not sure where exactly the menu is but I once accidently find out that such thing existed on our car when I try to reset the service interval.
Maybe some expert could chip in.
My Ride: G30 530i M-sport
Model Year: 2018
Originally Posted by bob.a' post='436684' date='Jun 17 2007, 07:59 PM
I've been reading posts that indicate the starting point of the arc of white bars on my LCI 520d's tach should vary, depending on engine temperature.
In fact, while the white bars are viewed through a window at the edge of the dial (and it seems possible there could be a mechanism to allow a variable number to be seen), they always run from 4600 to 5000 rpm - regardless of engine temperature.
Is my tach faulty, or is the last vestige of a temperature gauge disappearing from the LCI models?
The range covered on starting does vary, especially as the days are getting warmer now. It is not unusual for me to come back to my car at 6pm, after it has been parked all day (8-9 hours), start it, and find that the bars cover only the 4,600-5,000rpm band. Earlier in the year, this would not happen. See what it looks like on a particularly cool morning - it should cover a wider rpm range. If that shows no difference, I'd be tempted to get a dealer to look at the thing.
MacSid
Model Year: 2018
Originally Posted by big_ipaq' post='436876' date='Jun 18 2007, 10:38 AM
MacSid, the original poster is talking about LCI. All pre-LCI have this function, but looks like LCI does not.
My Ride: LCI E60 520d SE Manual, Jet Black/Natural Brown/Light Poplar, Auto A/C, Elec Front Seats+Lumbar & Driver Memory, SCA Doors, Thru Load, Auto Dim Folding Mirrors, Adaptive Xenons+High-beam Assist, LDWS, USB Audio, 244 wheels+RFTs (until worn) & S-S Spare
In light of other posts so far, it does seem there may no longer be any indicator that the engine has reached its unrestricted operating temperature, at least on some LCI diesels. Could this have resulted from a software bug, rather than an unannounced cost reduction?
As for people saying that a warm day affects their readings... IIRC I always have about 16 gradations reducing to four.
I would be very surprised even a 35C day would cause the gradations to reduce to the "4-bar" "running temperature" of the coolant.
There are no white bars in my 520d LCI whatsoever. I was under the impression that this is yet another example of goodies that the 520d has been deprived of in comparison with its 6 and 8 cilinder siblings (like stop-and-go cruise control, optimal gear advice etc.).
Originally Posted by aybeesea' post='436961' date='Jun 18 2007, 03:55 PM
On my diesel, the marks don't appear until the engine is started. Do yours disappear when the engine is off?
I would be very surprised even a 35C day would cause the gradations to reduce to an indicated "running temperature" of the coolant.
Just when you think you have a perfect car. I can verify that on my LCI when started up this am. Outside temp 65F that I had the base 4 bars and not the white hash marks up to 4500rpm like my 545i.
Either it only shows up when its really cold or its not functioning. I think mal-function as irrespective on engine temp, it should not be revved past 4,500rpm for the first minute to get the oil fully circulated.
