Jammed White Bars on Tachometer?
Old 06-17-2007 | 09:59 AM
bob.a's Avatar
My Ride: LCI E60 520d SE Manual, Jet Black/Natural Brown/Light Poplar, Auto A/C, Elec Front Seats+Lumbar & Driver Memory, SCA Doors, Thru Load, Auto Dim Folding Mirrors, Adaptive Xenons+High-beam Assist, LDWS, USB Audio, 244 wheels+RFTs (until worn) & S-S Spare
I've been reading posts that indicate the starting point of the arc of white bars on my LCI 520d's tach should vary, depending on engine temperature.
In fact, while the white bars are viewed through a window at the edge of the dial (and it seems possible there could be a mechanism to allow a variable number to be seen), they always run from 4600 to 5000 rpm - regardless of engine temperature.
Is my tach faulty, or is the last vestige of a temperature gauge disappearing from the LCI models?
Old 06-17-2007 | 10:16 AM
AC_S5's Avatar
The white bars will not all go away mine have a few at the end also and I think that have to do with the type of engine you have as every engine spec is different and the white bars are there to warn you to stay away from that rev range.
Old 06-17-2007 | 10:18 AM
big_ipaq's Avatar
AC_S5, yours are moving. bob.a says his are not moving at all.
Old 06-17-2007 | 10:38 AM
AC_S5's Avatar
He say it run from 4600 to 5000, I figure he's trying to say is moving from.
If not then get it check by the dealer.
Old 06-17-2007 | 10:45 AM
TitangrauII530iA's Avatar
My Ride: New ride from 14th May�07: 525iA LCI, Sport Suspension, Deep Sea Blue, Leather Dakota Natural Brown, Hi-Gloss Black trim, Star Spoke 124 18", Comfort Seats with memory, M -steering wheel, Glass Roof, Navi Professional, ProLogic7, USB-connection, Bi-Xenon, Extended Air Condition, Auto dimming mirrors, Electric Folding mirrors, Bluetooth for Cell Phone Sony Ericsson K750i, Electric rear window shade, Ligth package, Speed control with brake function, Cup Holders, Automatic head light control, PDC, Shadow line
Hi,
In my former 530iA 04/04 the amount of white stripes visible changed as the engine got warmer. In my current LCI 525iA there are always two stripes visible. Looks like they have changed it.
Regards,
jukka
Old 06-17-2007 | 10:51 AM
big_ipaq's Avatar
This is very bad, isn't it? The only indication that the engine is operating normal temperature.
Are you sure? Can anyone confirm?
Old 06-17-2007 | 11:05 AM
I am not so worried,
Overheating is indicated by display and after a cold start it is always necessary to use the engine "gently"
jukka
Old 06-17-2007 | 11:18 AM
big_ipaq's Avatar
I am, as I am not pushing hard, until I know the engine is warmed up. And this is my only indication... In winter, my white strips indicated 10-20 minutes. In Summer, at least half that. How I am now supposed to know when I am able to kick down without worries?
Old 06-17-2007 | 01:32 PM
boukehj's Avatar
My Ride: 520d LCI, old engine, manual, black dakota, platingrau II, standard (242?) rims.
Same here. No movement whatsoever. They are fixed at the range 4550 - 5000. (I also own an LCI 520d)
Old 06-17-2007 | 05:07 PM
Hormazd's Avatar
This is normal.
Quick Reply: Jammed White Bars on Tachometer?
